Question about Radio Shack Radio Communications
Realistic pro34 scanner receiver no power
Receiver no power
  • 32 Answers
Switch
Posted on Mar 29, 2013
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Will Realistic Pro 2021 receive digital frequencies?
If it does not say digital on the scanner the answer is no. If it does, most likely it is a trunking system and will require programming using software and a computer.
Nov 07, 2014 | Radio Communications
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
Is a realistic scanner a police scanner?
Yes.
Scanners do much more than just pick up police frequencies, but yes, the term 'police scanner' is commonly used in place of more appropriate names like Radio Scanner or Wideband Receiver.
Nov 11, 2009 | Radio Communications
SCANNER
Hello bigianne, You did not list the model #'s of the scanners and my telapathic powers are not working right today. For the uniden scanner go here and download your manual for your correct scanner #. http://www.uniden.com/index/manuals_results.cfm?cat=3
For the realistic scanner, that is Radio Shack, go here and do the same,,
http://support.radioshack.com/support_electronics/2849.htm
Hope this helps you out, and be sure to let me know,,, Mechanic
Oct 23, 2008 | Uniden Radio Communications
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Radio Communications Logo
29 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
