Question about Home Security
I have 2 garage doors, each with a Coromaster Mach II door opener.
If the electricity in the house goes off, or the plugs trip for any reason, one of the Coromaster Mach II door motors loses its limit settings. This also happens if the opening or closing is interrrupted by pressing the remote while the door is opening or closing. It is then a lengthy procedure to reset the limits on the problem motor, by switching off its power when it reaches open or closed positions. This has to be repeated many times - can take 1 to 3 hours. Pressing the limit button has no effect on its limit setting. The other identical unit does not have the same problem and continues to work normally after any such interruption. Any ideas?
lobsterman72
  • 91 Answers
SOURCE: Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Posted on Jul 01, 2008
Door Tech
  • 98 Answers
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Posted on Jan 17, 2009
SOURCE: Craftsman Garage Door not working, motor seems fine
I have similar jerkiness problem and have gone through all the nine yards of possible causes. The motor stops at random position and at random time. Even when I unhook the door from the carriage, it still showed this symptom. It started when I had one torsion spring broken. I replaced both torsion springs and adjusted for weight balance. Make sure the two cables windup properly along the thread of the pulley; Checked the photo eye sensors; checked/test capacitor; cleaned rpm sensor; adjusted all possible force settings; make sure limit switch at sound; re-programmed my remote just to check if the logic board somehow still work on this side and it did;
One important observation I have is that when I adjusted the carriage chain, I've noticed that the opener unit turns off and on as if there's a loose connection/contact. This I pursued more. The more I investigate, I spotted a "tiny" spark on one logic board soldering at the transformer footing as I **** the back panel (where the board is mounted) back and forth to simulate the on/off due to the loose contact observed earlier. This one solves everything! All I had to do is take the logic board out and re-solder that failed connection and Hooray - it fixed the problem!
Hope this helps someone with similar issues,
Viewful
Canton, Mi
Posted on Jun 18, 2009
  • 3197 Answers
SOURCE: Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Posted on Aug 26, 2009
swolfinor
  • 504 Answers
SOURCE: My genie H4000A garage door opener will not
UNPLUG RHE UNIT WAIT ABOUT 5 MIN. AND PLUG IT BACK IN.
THIS RESETS THE SEQUENCER.
SOMETIMES IT WILL SOLVE THE PROBLEM.
HOPE THIS HELPS
Posted on Oct 07, 2010
My coromaster door does not want to open by remote. It just makes a beeping sound.
have you changed your batteries lately, this is consistent with a bad remote or low battery
May 31, 2015 | Building Materials
Reset after a power outage
A couple possibilities- check for a tripped circuit breaker in your main breaker box, a surge may have tripped these or a fuse internal to the receivers (the inside units) was blown for the same reason
To prevent this kind of damage to all of your wired electronics, consider having a 'whole house' surge protector installed.
Cost: ~$200-$400 dollars and all units with which I am familiar are supplied with insurance against losses for 5-10 years and $10-25.000 in replacement cost.
Sep 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Coromaster garage door motors limits
When in doubt, Google it. If this gear attaches to a chain, it gets a little difficult to keep the chain in control. Usually parts like this are held in place by a set screw, requiring the correct allen wrench. Working this stuff up on a ladder is no fun.
Nov 24, 2013 | Building Materials
Garage wont open competely
There is a trip lever along the garage door track.
When door goes up, it trips the lever and turns off the opener.
The trip lever is adjustable. Loosen it and move back 1" or so.
If that is not far enough, move it back 1/2" more.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 20, 2013 | liftmaster Chamberlain Garage Door Opener...
Hi, i have a hotpoint WD860 washer/dryer and when it is turned on will blow the trip for the house mains, i have found today though that if the door is open it will not blow the trip, any ideas please
reason the machine blows trip probly damaged wire unplug mach remove lid and check wires around dryer unit this is often the scource good luck
Jun 08, 2011 | Washing Machines
I have a Coromaster Mach2 garage door opener. How do I code a second remote? Thanks
This appears to be something made in Africa. I suggest you call around locally. We don't seem to have any around here.
Jan 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lights on overhead unit on garage door opener will not go off
This is not too uncommon. What tripped the breaker in your house also got to one of the relays on the logic board of your opener. The only cure I know of is a new logic board.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener trips the GFCI
When garage doors get sticky, bent, and the chain needs lube they will trip the controls. A door may suddenly reverse for no apparent reason, that is friction. A GFCI is real sensitive to load. Also check the wiring to the unit. Any bad connection will upset the GFCI. Check all the way back to the breaker box, sometimes the screws on the wires need to be tightened.
Apr 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
129 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
