Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't turn off
The water dispenser in the freezer door of our GE side-by-side refrigerator won't turn off. The problem originally occurred a few months ago, but subsided after a day or two. Now, the dispenser drips constantly at a very fast rate. I have had to shut off the water supply to the water/ice dispenser to keep from mopping up the mess every hour. Before it began running constantly, the water was dispensing very slowly. This also was a recurring problem. Now it won't cut off at all. One note - the freezer door was replaced about 6 months ago as part of a class-action suit against GE. Apparently, many others were having trouble with these refrigerators. Ours was originally replaced because the ice chute kept getting clogged with ice chips that would melt and refreeze. I'd trade my current problem for that one, if I could. Any/all suggestions are welcome. Thanks.
  • 2 more comments
  • Bruce Moore Apr 12, 2008
    I have a very similar problem - the water dispenser won't shut off. For a while, I could tap the plunger and the water would stop, but then that would no longer work. Mine is just a shaft attached to the cradle that goes into the door and I can't see anything to lubricate. I have a GE TFX27ILN refrigerator. There is what looks like an access panel on the back of the freezer door. It looks like it may just pry off, and I tried, but was afraid it would break. How do I get access to the back of the dispenser unit? Do I have to take the entire back of the freezer door off, or how do I get the access panel off without breaking it? Or, is the problem more likely to be in the water line valve on the back of the refrigerator where the supply line is attached?
    I have a similar problem. I have a GE TFX27ILN refrigerator. The water dispenser would occasionally keep running, but I could tap the cradle and it would shut off. Finally, tapping it would not work and it would just keep running. I had to shut the water supply off. There is no place on mine to externally lubricate the switch (just a shaft that goes into the door). This refrigerator has what looks like an access panel for the dispenser on back of the freezer door. I tried to pry it off, but was afraid it would break. How do I get access to the back of the dispenser? How do I remove the access panel without breaking it, or do I have to remove the whole back of the freezer door? Or, is the problem more likely to be with the valve on the back of the refrigerator where the water supply line is attached? Suggestions?
  • Anonymous Aug 10, 2008
    Same problem. Water won't turn off.
  • jameslon Aug 14, 2008
    I have the same problem but it is a Sears Kenmore refrigerator. Cleaned everything I can see and sprayed with WD40 but NO LUCK stopping it.
  • 32 Answers
Stix: Check behind the dispenser handle the switch or button which is responsible to activate the mechanism of water dispensing. If the switch or button is covered with a reubber you must remove the rubber cap or whatever cover it has. If you have mineral oil or somekind of greasy stuff (vaseline or something similar) lubricate the switch or button. Open the freezer door and activate and deactivate the dispenser several times to lubricate the whole mechanism. SithPitt
Posted on Jul 04, 2007
SOURCE:
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
8,250 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
