Question about Electrolux Refrigerators
Electrolux sise by side fridge side stays warm.display shows -16
Electrolux E23CS78ESS1 display chows -16 fridge blend door not opening, Service replace main control board(241511102) due to minor flooding.
s4u311
  • 813 Answers
SOURCE: difficult fault on samsung side by side fridge freezer SRS615DP
u have to go with a good technesion
Posted on Aug 20, 2008
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 531 Answers
SOURCE: GE Profile GSH25SGPCSS Refrig. side thinks it's the freezer!
check damper control
Posted on Apr 02, 2009
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
markfreedman
  • 312 Answers
SOURCE: GE side by side. Top shelf in fridge warm. bottom
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Posted on Dec 29, 2010
Fridge digital display is showing CE, WATER DISPENSER BOT RUNNING WATER AND MOTER IS NOT ON
Hi berniekeenan -
Error code CE typically indicates a communication issue between the user interface and main control board. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the refrigerator back on. If the error code continues, I recommend scheduling service so a technician can accurately diagnose and repair your refrigerator.
Apr 20, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
Heater blow warm air on one side and cold air on the othe
the blend door is staying stuck open its a door inside of your air vents
Dec 11, 2010 | 1994 Buick Park Avenue
My 2000 Grand cherokee only blows warm air from defrost or any vent, 105 to 110 on a 32 degree morning with high fan, about 10 degrees warmer on low fan. It gets warmer when it warms up outside.Engine...
This is a common problem with WJ Grand Cherokees, it's called a "Blend Door".
In the heating and cooling system you have doors that open and close to give you warm and cold air and a mix of both.
What you have is an arm that pulls a door with peg on top, the peg tends to snap off. As you said your dealer replaced the blend door or doors I would take it back as is has blend door all over it.
Yahoo and youtube "jeep grand cherokee blend door repair"
I had a 02 limited blend doors issues (note the issueS) and was lucky to have it still covered.
I do hope this helped.
Nov 24, 2010 | 2000 Jeep Grand Cherokee
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Apr 04, 2009 | Electrolux Refrigerators
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
23 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
