Question about Microsoft Word Home and Student 2010
Software freeze up
Word frezzes my laptop. Is there a fix for this problem? My laptop is a HP running on Vista 64 bit.
  • Microsoft Master
  • 27,725 Answers
You might have to many programs trying to or accessing your computer or the internet at the same time or a virus Scroll to bottom toolbar (bottom of screen) right click select task manager applications and processes to see you whats running and ticking over if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be running select end now
You might have to uninstall the current version of word you have on your computer then restart your computer then run the jet clean utility. http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. Then reinstall word Hope this helps.
Posted on Jan 11, 2013
  • 70 Answers
SOURCE: 32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Posted on Feb 07, 2009
  • 121 Answers
SOURCE: iTunes ''not responding'' using VISTA 64-bit
are you running itunes 64 bit? that would be your solution there. download the 64 bit version and it'll solve all your problems.
Posted on Aug 04, 2009
  • 52 Answers
SOURCE: how to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Posted on Sep 03, 2009
SOURCE: How to Install American Greetings Creatacard Plus 3 on Microsoft Vista (64 Bit)
Need to update American Greetings 3 Creatacard Plus
Posted on Jan 01, 2011
ratheeshmoha
  • 349 Answers
SOURCE: I have licence of Windows 7 Home Premium 64 bit
use in 64 bit software
Posted on Sep 22, 2011
Download for a x64-based PC . every time i try to update it tells me i need either a (x86)bit or (64)bit . my system is 64
The computer hardware may be 64 bit but is the Operating system you have loaded 64 Bit or 32 BIT?. If you have a 32 Bit operating system loaded this would explain your problem.
Feb 25, 2015 | Toshiba Satellite Computers & Internet
Tip
How To Diagnose HP All-in-One Scanners
<a href="/ftp://ftp.hp.com/pub/softlib/software12/COL34826/oj-90928-1/HPSDU.exe">HP Scan Diagnostic Utility</a> was created to help users troubleshoot and correct connectivity problems with HP All-in-One devices and software on Windows-based computers. Follow the on-screen instructions to run the utility.<br /><br style="font-style: italic;" /><span style="font-style: italic;">This utility is compatible with Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Ultimate (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP</span><br /><br />You could also try running the HP System Check if you have <a href="http://h50203.www5.hp.com/HPISWeb/customer/SupportProds.aspx?region=NA">any of these supported products</a>. HP System Check automates and speeds the resolution of computing problems, acting as a Web-based diagnosis and resolution service. System Check offers a unique combination of Web based trouble-shooting software and world-class hardware diagnostics, providing the most comprehensive array of online support solutions in the industry. Check your system by <a href="http://h20239.www2.hp.com/techcenter/HP_SystemCheck/hp_syscheck.htm">clicking here</a>.
on Feb 21, 2011 | Office Equipment & Supplies
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Hi, i have an HP printer D5160 and the desplay shows the err 03 31 if f4 dd6 and i can't print anything Thank you Aris T.
Oct 27, 2010 | Office Equipment & Supplies
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Unable to install mt Lexmark x1150 all-in-one printer to my HP laptop with vista.
Use the driver from the Lexmark website. First, uninstall properly any existing Lexmark X1150 driver from HP laptop by following the instructions available at http://bit.ly/8ZH59T. Then, check if your Vista is running on 32-bit or 64-bit operating system by going to Start menu > right click on Computer > Properties. Download the driver available at http://bit.ly/bSr2PH(32-bit) or at http://bit.ly/bx4y3o(64-bit). Execute the file and follow the instructions in the software. Thank you for choosing Lexmark.
Sep 19, 2010 | Lexmark X1150 All-In-One InkJet Printer
Freezing magix music studio 12 deluxe with vista 64 bit
I think the problem is..... Magix is compatible with XP 64 bit but not with Vista or 7 64 bit, not much 3rd party software is.
Sep 12, 2009 | Magix Music Studio 2005 Deluxe for PC
I cant install autocad 2009 in windows vista 64 bit operating system.
I cant install Autocad 2009 on Acer Apire 5715z, when i try to install the operating system is not supporting
regards,
Johnson Idukkula johnsonkollam@gmail.com
Mar 05, 2009 | HP Pavilion dv4000 Notebook
32 BIT OR 64 BIT?
I beta tested Vista 64 bit, and had very little problems running 'most' software I had.
Without knowing the specific software you will be trying to use, it's hard to tell. Most software manufacturers DO offer their stuff in 64 bit, but it's often NOT included on the installation disks.
For the average user, I would stick with 32 bit, only because some programs won't work under 64 bit, unless it states 64 Bit compatibility right on the software box.
Apr 14, 2008 | HP Pavilion dv6000z Notebook
Microsoft Word Home and Student 2010 Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
