Question about Dehumidifiers
Charging a kingavon dehumidifier
What position shold the dehumidifier be in when charging
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Nov 10, 2013 | Danby DDR600R Silhouette Dehumidifier
My dehumidifier keeps beeping??????
The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
May 05, 2011 | DeLonghi DE400 Dehumidifier
Not sure if I should charge the Remington 365 Mini dehumidifier before I use it for the first time.
If the little indicator ball is Blue at present, it doesn't need to be charged. Only charge it once the ball changes to Pink.
Hope this helped you.
Apr 20, 2011 | Remington Model 365 Dehumidifier
Will not shut off in the off position Starts and
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 23, 2011 | Kenmore 54351 Dehumidifier
Dehumidifier freezes up within 10 mins of run time. does not matter where the temp is set at.
The unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 29, 2010 | Goldstar DH2510A Dehumidifier
Dehumidifier element icing up
Unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
May 29, 2010 | Maytag M7DH45B2A Dehumidifier
Its plugged in, bucket is in position, but wont run no lights nothing
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 08, 2010 | Kenmore 54501 Dehumidifier
My kenmore dehumidifier compresor runs the fan runs but no water in the bucket . Compresor freon lines both same to have the same tempature ( flow and Return ) . Is a freon charge the answer ?
More than likely not. I would start by making sure all coils are clean, (both evap and condenser) and to make sure airflow is not being obstructed. Most factory charges appliances don't leak refrigerant and therefore should not have to be charged during there useful life. Hope this helps
Sep 22, 2009 | Kenmore 53509 Dehumidifier
Running but not dehumidifying some icing on side of unit have followed instructions in manual, to no avail
heatman101
Aug 01, 2009 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
98 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
