Question about Ovens
Tecnik oven TCK8525/2
We do not know how it works
I gather Tecnik are no longer in production. I am looking for the oven seal for the TKC8126 and do not know where to find this part.
Contact a local appliance repair business and see if they can help, this site has no resources for parts.
Oct 13, 2016 | Tecnik Ovens
Manual for TECNIK oven Type HM46347
http://www.manualslib.com/manual/654296/Tecnik-Oven.html
http://www.ukwhitegoods.co.uk/help/about-the-appliance-industry/manufacturer-information/2804-tecnik-domestic-appliances.html
Sep 08, 2014 | Tecnik Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Problem with electric single oven Tecnik tkc241/2
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Tecnik TKC215/3 Electric Single Oven
Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Tecnik TKC8525 Double Oven
Tecnik oven inner glass has fell out. how do i re-fit it
i have never managed to be able to reglue this type of door. you are faced with buying a new part
Sep 30, 2008 | Tecnik TKC8525 Double Oven
Need User Manual
Hi Martin Have you had any luck with this? I too need a manual for this oven, and should be (hopfully!) receiving one from Germany in the next week or so. If you haven't had any luck, let me know and once I receive the manual I can maybe help? Regards. Louise.
Dec 11, 2006 | Tecnik TKC8085 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
