Question about Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive
My external hard disk doesn't been connected to the computer when i plug in the USB and i need to plug and unplug it many times to let my laptop recognize ir
Remove the drivers you have for the usb and re install them
Posted on Jan 11, 2013
kamal1984
  • 1383 Answers
SOURCE: Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Posted on Jul 20, 2009
chanddra2009
  • 615 Answers
SOURCE: External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Posted on Sep 17, 2009
SOURCE: External Hard drive not showing in my computer
thanks for your question...
please change the hard disk compartment and do it carefully.
Posted on May 20, 2009
  • 1481 Answers
SOURCE: I am using Transcend 320 GB external hard disk in
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Posted on Feb 17, 2011
cristi_mc
  • 55 Answers
SOURCE: Transcend store jet 25 mobile
Go to www.transcendusa.com, this is official site for transcend products. You will find there a little program to restore functionality of your hdd (this in case hdd have no bads on disks), run this program and see after that if is ok. Good luck!
Posted on Mar 21, 2011
120G hard disk doesn't work on p4m266a mother board
The hard disk maybe faulty especially if the BIOS cannot detect the hard disk.
Try connecting the hard disk into an USB hard drive adapter and then plug it into the USB port of a working computer. If this computer cannot detect the USB hard drive adapter as an external storage device then this hard drive is faulty.
Oct 29, 2012 | Computers & Internet
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
My laptop doesn't recognise external hard drive
Most Windows versions:
Go to the diskmanagement (run compmgmt.msc) option Disk management.
Locate the drive and add a driveletter.
If the drive is not shown in the list, you need to check your USB drivers or connectors.
Jan 15, 2012 | Medion Computers & Internet
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Jul 28, 2011 | HP Pavilion DV9740US Laptop
Media test failure insert cable
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 22, 2011 | Computers & Internet
THINKPAD hard drive stuck
Do you mean the computer cannot seee or boot from the hard disk?
If so then this usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 30, 2011 | Lenovo ThinkPad T410 Notebook
PXE-E61: media test failure,check cable PXE-M0F: exiting PXE ROM
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the laptop/computer, Windows installed and the computer's or laptop's device driversplus your programs etc. to get a functioning computer/laptop again.
May 19, 2011 | Computers & Internet
Have brought a new external hard drive for my laptop, i've plugged it in and the system sain it was installed successfully but its not showing in my computer have tryed restarting a few times, i've...
If you are using a usb hub disconnect it completely and try connecting your Western Digital directly to a usb port on your laptop. If that doesn't work try booting into safe mode and see if it shows up then. If it works in safe mode a recent update to your virus program or another program could be blocking it. Hope I was of some help , Thanks for using FixYa
May 11, 2011 | Western Digital My Book Essential Edition...
A disk read error occured press control+ alt+delete to restart
The hard disk may just need reseating or it may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the computer and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
May 06, 2011 | Computers & Internet
Wont show hard drive
First - re-seat the harddisk (to ensure the hard disk is properly connected to the motherboard) and then reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Apr 21, 2011 | Computers & Internet
Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive Logo
172 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
