Question about Samsung Easy 1300 Lightweight Compact Canister Vacuum Cleaner
Samsung easy 1300 hose broke
Where to buy it
Broke hose on my bissell
Bissel. com actually sells the parts quite cheaply.
I have one of their "Spotbots" and you can get most of the replacement parts right on the site...
Feb 16, 2014 | Vacuums
Vacuum bags
It would help to know your postal code in order to to find a shop that caries bags for that model. Otherwise you can get them online such as amazon. Samsung Type VP-95 are the bags and should be readily available; also evirocare make a bag for them which is package #211.
Nov 12, 2013 | Samsung Easy 1300 Lightweight Compact...
I have a Samsung 4320 vacuum cleaner which has started making a loud blowing noise as if the hose is split. I can't find a split in the hose and it isn't blocked. Also it isn't picking up very well. ...
Most vacuums have an air duct on the hose to adjust the amount of suction. If this becomes opened, you will hear the sound you've described and the suction will lessen. Check the wand and the hose and see if you notice a sliding piece that can be moved to enlarge or decrease an opening in the wand or hose. Use this to close the opening and your machine should work as it's supposed to.
Hope this helps and good luck!
Mar 07, 2011 | Samsung Easy 1300 Lightweight Compact...
H3000 recovery hose broke. How do I remove the
You can find a link to the schematic below. The schematic points out where all the screws are on the H3000. You can also find any parts that you need to replace.
H3000 Parts
Feb 06, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Rainbow D3C electric Hose is broke
NO NO NO NO you have to get a new hose in this situation there is no other way around it. If you screw up just the littlest bit reattaching that hose a vacuum that uses water will QUICKLY let you know. Do yourself, your family, and your life insurance company a favor and buy a new hose.
Apr 10, 2009 | Rainbow Technologies D4 Bagless Vacuum
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Mar 13, 2008 | Vacuums
Samsung Easy 1300 Lightweight Compact Canister Vacuum Cleaner Logo
114 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
GARY HIVELY
Level 1 Expert
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
