Question about Refrigerators
The fan in the freezer is not working
THE FREEZER IS STILL WORKING BUT THE FAN HAS STOPPED WORKING AND THE TOP SHELF OF THE FREEZER IS NOT GETTING COLD ENOUGH TO KEEP THINGS FROZEN
  • 17,129 Answers
Possible that the fan has failed, check the voltage on the connecting pin to the fan , if present the fan is faulty, if absent then there is fault in the control board.
Posted on Jan 12, 2013
  • 1122 Answers
SOURCE: Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Posted on Mar 16, 2009
  • 72 Answers
SOURCE: refrig & freezer set to coolest but not
is it buzzing and clicking every few minutes?
Posted on Jun 16, 2009
SOURCE: fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Posted on Aug 09, 2009
  • 19 Answers
SOURCE: Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Posted on Aug 27, 2009
toolkits
  • 1099 Answers
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
We have ice/frost buildup in the top shelf of freezer and the refrigerator compartment seems too warm. Can you give possible remedies? Thanks.
check the circulating fan that circulates air from the freezer compartment to the fridge.. may have stopped working.
Oct 10, 2015 | Refrigerators
Why top section of my freezer it is not working?
Some time you just need to check - if upper shelf of your freezer LOADED TOO MUCH, if the food packs or any things blocking air flow on very top shelf, so it's simple and first step. Then you need to check a fan switch - it is on door frame, push it - can you hear a fan noise? No? Yes? If no - check switch, if switch is good and evaporator fan powered on - replace that fan! :)) top-section-freezer-not-working-r1jn5krxv4u25asvnln3jun1-5-0.png
Sep 21, 2014 | Sub-Zero Refrigerators
Daewoo frs-U2OIC top shelf freezer not freezing
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Feb 13, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
The bottom refrigerator don"t get cold. water was leapin on bottom shelf be fore it stop working. Thank you
Look for frost build up on the back panel in the freezer side. If there is then you'll need a defrost timer or heater. Also check to see if you can hear the fan running in the freezer, if not that's your problem...replace it. All the cold air comes from the freezer it needs the fan to get it to the fresh food side.
Oct 20, 2010 | Frigidaire FRT15B3A Top Freezer...
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
REFRIGERATOR NOT COLD
I have experienced this also.
If the drain under the evaporator coils in the freezer freezes up it will cause this. Because the coils ice up. Manual defrosting with hair dryer will get working again, but if drain is stopped up it repeat.
Maybe piece of paper or food in it.
OR the defroster heater element is burnt out. Same results.
Most all top Freezer Models.
Nov 13, 2008 | Frigidaire FRT21H8 Top Freezer...
Water on bottom shelf of FRT15B3AW3
is the fan still running in the freezer compartment???? it may be your defrost thermostat.....
Aug 18, 2008 | Frigidaire FRT15B3A Top Freezer...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
