Question about GE Washing Machines
Model # whse524od1ww does not spin out
Will not spin out
Kenmore he21 washer fill agitates drains but will not spin
Hello;
My name is Peter. I am a retired field service technician.
The model number you gave HE21 comes up as a Maytag hot water tank.
Open the front door of you unit. The model number should be at the top on a tag.
Repost your question with this model number.
Nov 10, 2014 | Washing Machines
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Jul 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Model LSQ9659PWO washer does not spin , just makes
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Manual claims machine has ability to spin out water but there are no options on the control panel
There are different models withing this line by GE. There is one model that have a "Drain & Spin" cycle on the main cycle selection knob, but on the higher end models, you'll need to use the "Rinse & Spin" cycle.
This will add some water to the washer, but the basic cycle will give items a quick rinse and spin.
If you're trying to use just a spin cycle to wring out towels, etc. and you don't have the "Drain & Spin" cycle, (which you shouldn't based on your higher end model #), just use the "Rinse & Spin" cycle and it'll do a nice job of getting out a lot of moisture from your clothes, towels, etc.
I have this same washer in my own home and refreshed my memory by reading my manual (again) to see that this is what you need to do, to spin out stuff.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE WCVH6260FWW
My maytag washer model PAV3300AWW will not spin
Check the belt at the bottom of the machine. You can also remove the back panel. Either the belt has become stretched or broken and needs to be replaced
May 22, 2009 | Washing Machines
I have a ge washing machine that on the spin cycle kicks on and off
Don't know the model but if it is a two speed model and is clicking off and on when set for high speed spin but seems to start up and spin OK in slow speed spin, you have a bad motor
Dec 19, 2008 | Washing Machines
Dryer does not spin
Usually if a dryer won't spin, I suggest checking the belt to make sure it isn't broke or even the motor burned out. If you post a model number for your dryer, I may be able to assist you further.
May 28, 2008 | Dryers
Washing Machines Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
