Question about AcerPower F2 PC Desktop
Red light n green light stayong during boot blinking light on video
I try n get it to boot uo the hard drive red lights stays on n wont go into xp
Have you tried booting from last known good config , and if you flash your bios by unplugging yr pc and removing the cmos battery for 10-15 mins and then replacing it back then power then turn it on that shud do the trick other wise you have a hardware issue that can only be sorted by replacing the hardware
Posted on Jan 11, 2013
  • 3 more comments
  • toddy1225 Jan 11, 2013
    ty my friend will try that i just thought of that when i got ur email will let u know ty
    it worked my friend n i had wrong memorey in there had 3200 n 2700 would work so now have the same it worked ty ty ty my friend
  • psyfox30
    psyfox30 Jan 12, 2013
    GOOD GOOD GLAD TO BE OF ASSISTANCE IF YOU EVER GET STUCK WITH ANYTHIN JUST ASK
  • toddy1225 Jan 14, 2013
    it didnt work i thought it did soory dont know what it could be will try several things
    ok back again it was hard drive errrrrr shold of known ty again for giving me the solution k
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on , blinking red light appears, any answers please
Hardware issue.
You can try booting the PS3 without the hard drive installed but in almost every case of the blinking red light it's related to the motherboard / power supply unit.
I'd recommend sending it to Sony direct for service.
1-800-345- Sony
You can check out this page or some tips / details.
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
It turns off and the red light blinks.
blinkin red light usually means hardware failer the only 2 easy tricks to try that wont void your warrenty is
#1 remove the hard drive and boot it up without it and see if it boots and says no hard drive then shut it down and plug the hard drive back in if it works now then was just a drive error if it goes back to blinkin you have a bad drive.
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps3 off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
The red light on my ps3 is blinking and wont stay on
Turn off the ps3. Try reseating the hard drive. Take the cables off and then hook them back up. After this turn the ps3 back on and see if the blinking red light goes away. If it doesn't then try another hard drive in the system. If the blinking light goes away then you know you have a bad hard drive. If the blinking light does not go away then you know either the power supply or main board is bad.
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Does the computer turn on all the way now or does it start to boot and then turn off?
Your Power Supply is no good, you are going to have to get it replaced. Once you get it replaced everything should be fine.
Jan 02, 2009 | Dell Dimension B110 PC Desktop
Black screen and no blinking green light when turned off
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-6 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i amafrikaans BUT PLZZZ RATE ME . . . plzz thns
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
I have blinking green & red lights on my xbox & its not a 360
your Xbox may not be plugged in right, look at your manual at the installation instructions
Oct 25, 2008 | Microsoft Xbox Console
AcerPower F2 PC Desktop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
