Question about Linksys Wireless-G WPS54GU2 Print Server
Well you please tell me default IP address of LINKSYS Wireless-G Print Server
  • Anonymous Feb 19, 2009
    How find a ip address ??
  • 1,031 Answers
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Posted on Jan 22, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 22, 2009
    To have your wireless settings checked if you are using a Linksys Wireless Router, here's how:
    Wireless Security Check
    1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
    2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go
    3. The "Enter Network Password" window will appear.
    4. Skip
      user name and type admin (admin is the default password) as the
      password, and click OK If it does not accept the default password, try
      the password you might have typed in when you ran the run me first CD
      that came with your router.
    5. On
      the Setup page of the router, click the Wireless Tab on the top and
      take note of the SSID, change the channel to 1 3 5 7 9 or 11 to get a
      better frequency then click the save settings button on the bottom. You
      would need this for the wireless settings.
    6. Click
      the Wireless Security Sub tab then take note of the KEY1 if WEP is
      enabled, if this part is disabled then your router is for open
      access(means no security is enabled and any device should be able to
      obtain a connection). You should have no trouble connecting if this
      part is disabled.
    7. After
      typing in the network key on your wireless computer, your wireless
      connection should be established. Launch your Internet Explorer, and
      then you should be connected afterwards.
    8. Go
      to your WPS54G's setup page by typing it's IP address on your address
      bar. (You can get the IP address of your print server by pressing the
      reset button on your device for 3 seconds then it will print out its
      status).
    9. Leave the username blank and type admin as your password. Hit OK afterwards.
    10. Click
      the wireless tab on the top and make sure the SSID is the same as your
      SSID on the Router. Then click the WEP key settings button if you have
      WEP enabled on your Router.
    11. Save the settings.
    12. Detach
      the printserver from the Router and unplug its power cable. Plug it
      back again and wait for the WLAN or Wireless light to turn on.
    13. Then try printing wirelessly now.
    This
    should get your printer working wirelessly afterwards. Make sure your
    printer is online at all times. Hope your printer works! Good luck!
    i will appreciate a fixyaa rating thanks and Godbless
  • 4 Answers
U can go to the printer setting Wireless settings & also select the default ip than you can install the Wireless-G printer
Posted on Feb 24, 2009
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Wireless-G WPS54GU2 Print Server Lost disk
if you visit the LinkSys website you should be able to download all applicable drivers and files for this print server. Also you will likely be able to access a user manual (in PDF format) which should give you all the information you need.
May 27, 2008 | Linksys Wireless-G WPS54GU2 Print Server
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Linksys Wireless-G Print Server
Dear Davisj, This is a typical problem that occurs when you have an active firewall. Try disabling the firewall and you should be able to print. Linksys is known for their customer service and expertise, I would suggest giving these folks a call at: 1-800-LINKSYS, they will walk you through the process of setting this up correctly. If you don't want to call, the problem lies in your firewall. Look for the IP address on the printed test page. If you are using a Linksys router with a default IP address of 192.168.1.1, the printserver should be getting an IP range of 192.168.1.x as well indicating that it is properly obtaining an IP address from the network. Once you locate your IP address all you need to do is go to your Firewall settings for your Mcafee software and add permission to add a specific IP address and you will enter your Print Server's IP address. This should fix your problem! Good luck! The following link should provide you with additional details to fix your Print Server: http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859942287&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=4228741076B05
Jan 20, 2007 | Linksys Wireless-G WPS54G Print Server
Linksys Wireless-G WPS54GU2 Print Server Logo
846 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
