Question about Samsung N145 Plus 10.1 inch Netbook - Black Intel Atom N455 1.66GHz, RAM 1GB, HDD 320GB, LAN, WLAN, Webcam, Windows 7 Starter
My keyboard wont type - Samsung N145 Plus 10.1 inch Netbook - Black Intel Atom N455 1.66GHz, RAM 1GB, HDD 320GB, LAN, WLAN, Webcam, Windows 7 Starter
  • Samsung Master
  • 27,725 Answers
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
b>
Posted on Jan 12, 2013
My keyboard wont type,even went out and bought a new one still wont type
Presumeyou've got Windows. Try to start up in SAFE mode and verify if your keyboard works.
An ultimate test might be to start up using WinPE - a very basic CD resident Windows. You can download one from
http://www.uploadable.ch/file/mKD6atNTMRGF
Try to Resore System to a point BEFORE this problem started
Mar 04, 2015 | Computers & Internet
Asus keyboard wont type on internet
What broswer? IE? Firefox? Google Chrome? Etc.?
Feb 08, 2013 | Computers & Internet
Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
Aug 21, 2011 | Dell Latitude D600 Notebook
I start typing and my keyboard contunie typing one letter for Example: Youtubeeeeeeeeeeeeeeeeeeeeeeee.... And it wont stop!
It looks like the e key is stuck down and this is causing eeeeeeeeeeeeeeeeeeeeeee
It is like holding down any key on the keyboard.
Jul 13, 2011 | Apple (076-0982) Keyboard
My uiop keys wont work, on my laptop keyboard.. I have replaced it many times, and now my uiop keys wont work -- typed on On Screen Keyboard
you must have configured the settings incorrectly when you installed the OS.go back and repeat procedure choosing correct type of keyboard.
keyboard configuration is a basic function of all operating systems
Sep 12, 2010 | IBM ThinkPad T42 Notebook
Hp keyboard has a late reesponse and wont type
Open control panel select keyboard and double check input speed which you can adjust to suit you.
Jan 25, 2010 | HP NB199UA Pavilion Notebook
My keyboard and mouse doesnt work properly, and i change batteries on it twice. cursor wont move or its jumpy,and keyboard wont type
Make sure you have the correct dirvers for your windows version. Also make sure you have current firmware version software by going to the manufactor's website.
Dec 11, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard wont work . wont type words..when i try to type in my password nothing will type.
Reboot the system in safe mode and see if its working, If its not at all responding then it is a hardware issue and need replacement of the keyboard... Thanks
Dec 05, 2009 | ASUS Computers & Internet
Do you mouse work?
if you just change your batteries and your mouse work, just synchronise your keyboard with the receptor.
In the back of your keyboard, they are a small button; press it and press the small button in receptor to synchronise!
Oct 06, 2009 | HP Computers & Internet
Keyboard wont type mouse is working
Please send full setails, is it USB or PS2 keyboard, operating system, You can try following before sending details.
1. Right click my computer then properties then hard ware. then device manager. See keyboard is listed against + sign, if yes expand it and see "Standard101/102-key or standard Microsoft manual PS/2 keyboard. If Yes the right click on it and update driver. If problem is not solved click on properties ans see device status " device is working properly. Further try to uninstall and remove USB or PS/2 cable and reinstall . Reboot the system.
Nov 11, 2008 | Logitech 967437-0403 Keyboard
Samsung N145 Plus 10.1 inch Netbook - Black Intel Atom N455 1.66GHz, RAM 1GB, HDD 320GB, LAN, WLAN, Webcam, Windows 7 Starter Logo
164 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
