Question about Taylor & Digital Scale Lithium Scale
I have a lithium electronic scale 7345 . weiigh approx 191 lbs. when I weight myself, scale show 180 lbs. but never the same weight.
  • Anonymous Dec 27, 2015
    Was getting an error when I changed the battery. This fix worked... would NOT have guessed.
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
skaterkid307
  • 86 Answers
SOURCE: How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Posted on Feb 20, 2010
SOURCE: can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
F1xer
  • 415 Answers
SOURCE: Taylor Model 7314 Lithium Scale: Scale
Try stepping off the scale when you get an error message wait 5-10 secs then step back on, remember to stand still when the scale is giving a reading
Posted on Aug 15, 2010
taran_2005
  • 10515 Answers
SOURCE: we have a 7542 bathroom
The procedure to reset the error is :-
REMOVE YOUR FOOT.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 06, 2011
Salter scales
Maybe the battery needs replacing its what happened with mine I replaced battery and its been working fine ever since.? 1 CR2032 lithium battery .
Jan 25, 2014 | Health & Beauty
I need a manual for simply bathroom body analysing scale
Could someone tell me the battery needed for the Simply Bathroom body analysing scale - model 4528?
Thanks
Apr 16, 2012 | Health & Beauty
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
Apr 19, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
When i step on the scale it shows error2
You have exceeded the max weight for the scale
May 31, 2010 | Taylor 7329 Electronic Lithium Scale
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Taylor & Digital Scale Lithium Scale  Logo
863 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
