Question about Electrolux 18 in. ESL424 Built-in Dishwasher
Dirty water sitting in base of machine after cycle and will not drain away when starting the next cycle
  • Electrolux Master
  • 17,130 Answers
Click this link to see how the dish washer can be cleaned
click on : cleaning machine
Posted on Jan 12, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My dishwasher is not draining
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Aug 25, 2011
My Kenmore compact washer with dryer on top, will not go from the first wash-rinse-drain-spin cycle to the second rinse-drain-spin-off cycle.
Check and make sure the door is pushed all the way down until you hear a click. If it starts with the next cycle, then your door switch may be bad. It's a pretty easy fix, but I would watch a video at least before doing it yourself.
Oct 09, 2016 | Kenmore Washing Machines
Washing machine does not agitate or spin.
get a new control board /timer switch (Depending on your make of machine)
Jan 18, 2016 | Washing Machines
Maytag lsg7806aae tub does not drain before spin cycle starts
Drain pump getting clogged or jammed I would start there.
Apr 19, 2013 | Maytag Washing Machines
Slow running sink
Use a caustic based drain cleaner (draino) and let sit for maybe 10 minutes. Put in the plud and fill tub to about half then pull the plug. Repeat if not successful first time and let sit longer
.SAFETY FIRST--- CAUSTIC BASED DRAIN CLEANERS MUST BE USED AS PRESCRIBED AS THEY WILL BURN THE SKIN AND DAMAGE THE EYES IF SPLASH ABOUT kEEP WELL AWAY FROM CHLIDREN EVEN THE CONTAINERS, But they work very well on blocked drains.
Mar 13, 2013 | Washing Machines
Excess detergent light keeps coming on even when not adding detergent
1st check your hose connections they may be dirty or or clogged then use a chemical like draino or liquid plumber if you still have problems with your hose connections it may be your washing machine itself then you may have to contact your local plumber if he can't find the problems with your washing machine you may have to get a new washing machine
Jan 28, 2013 | Miele W460WPS Front Load Washer
After washing clothes smell stale. We have tried adding more detergent without success and draining the pump on a regular basis. Any ideas?
Check the drain pipe at the rear of the unit, sometimes the position allows the dirty water to re-enter the washing machine and sit there between cycles. Some units have a rigid plastic holder to ensure the pipe is curved at a specific height so the water empties using gravity as well as the pump. (Same process as syphoning liquid, once the liquid is flowing through the pipe, gravity continues to **** the liquid through) You may also need to check the pipework from which the detergent/softener enters the unit as these can sometimes go a little mouldy. Once you have looked at these two problems, run the machine empty on a high temperature cycle to clear away any disturbed grime.
Good luck, hope I was of some assistance
Aug 05, 2011 | Washing Machines
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
It isn't draining. There is dirty water sitting in the bottom of it. Tried to see if anything was blocking the drain but couldn't find anything.
Check the entire length of the drain hose from the washer bottom to the connection at the sink drain for kinks--you may need to pull the machine out of the cabinet part way to check. Make sure the hose passes over a point higher than the drain connection at the sink. If you have access to a wet/dry shop vacuum, remove the sink end and **** the water out. If nothing comes out, then there is an obstruction somewhere. Use the vacuum to **** the drain opening inside the washer.
Sep 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Beko d2731fw the dishwasher is just sitting on the drain cycle , the selector isnt changing anything , could this be the timer or something else.
Anti -flood could of activated? now just set to drain , need to disconnect power and pull machine out and tip it back to see if any water is sitting at base of the unit, please remember to put towels under and around the base to catch any such water?
If you have water there it could mean a link , need to tip machine on its back (after removing water by tipping back) undo the 4 screws and visually check for loose or cracked pipes? if loose pipe a simple jubille clip could solve possiable problem?
Jul 20, 2009 | Dishwashers
Electrolux 18 in. ESL424 Built-in Dishwasher Logo
111 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
