Question about Motorola Mobility MOTOROKR E6
Speakers automatically stops and starts frequently
My speakers gets stop automatically and after 1-2 days it automatically starts. It is happening frequently. Please advice
  • 3 Answers
In case of any software problem it will happen u better make a maser rest.
Posted on Jan 25, 2009
My new speakers in my 2004 1500 chevy dodge ram stopped working randomly.
Go recheck for loose connections at both ends (the radio-harness and the speaker).
Jan 10, 2013 | 2004 Dodge Ram 1500
I have logitech Z4 speakers, and my speakers always just stop working, then when they're un plugged and re-plugged in they start to work again. This issue used to happen every couple of days, and
• One possible reason could be a faulty power supply for the amplifier.
• Transformer could be overheating or possibly the main amp itself.
here is a link , should you need to DIY
or just a guide and use it as a reference.
404_118x100.png Computer Speakers
let me know if you need more assistance.
Sep 11, 2012 | Logitech Z4 Computer Speakers
I have Mercury 2.1 white speaker.It works fine for half an hour but after that the woofer's sound stops-start frequently at highest bass but when I reduce the bass It works normally with no distortion.
If highest bass means you are boosting the bass for effect then it may be some form of speaker protection cutting in.
The most likely is a Polyswitch, which increases in resistance as it heats up when too much current is going to the speakers. The sound resumes when it has cooled down.
Feb 11, 2011 | Jasco GE 98903 2.1 Speakers
Right speaker stopped working?
Hello.
This is a very frequent case and it is not rare.
These speakers usually are not that much of a high quality, so the chances that these speakers (or one of them) will stop working is very high.
First of all, to check that hte speaker isn't corrupted, try making sure that all the necessary cables are properly put in their places:
Check that the two speakers are connected to each other (usually a cable coming out of the back of the speakers).
Secondly, check that your computer has not muted the right speaker:
Go to Start -> Control Panel -> Sound and Audio Devices -> Click "Speaker Volume..." button under the Speaker Settings frame -> Set all volumes to the max (Drag the slider with the mouse to the high right)
If none of the solutions worked, then there's a 99% chance that the right speaker has been corrupted or is malfunctioned. If so, I recommend buying a higher quality set of speakers.
Good luck.
Dec 16, 2010 | Dell A215 Computer Speakers
My jvc mx-d622t shelf stereo simply stopped working. No power at all , Course I do have 6 speakers hooked up to it, just added the third pair the day before it stopped working.
Are these speakers compatible or are you just adding speakers because you have them hanging around?
If you have effectively less than 6 ohms of impedance on any channel you may run into problems and the unit may either die or protect itself by refusing to stay ON.
It's fairly obvious that if you do X and undesired Y happens you might want to UNdo X and rethink it.
May 29, 2010 | JVC UX-GP5 Micro Stereo Audio System Shelf...
My speakers started buzzing and making a horrible noise during the night. I had to unplug them to get it to stop. What's going on?
Feedback. Check the wires, might have a bad connection. Wiggle them around and see if the buzz sound stops or changes. If that happens, its usually that wire. Good Luck.
Sep 10, 2009 | Harman Kardon HK695 Computer Speakers
Dell inspiron1525 laptop trouble
This is going to be a problem either with the sound card malfunctioning after the machine warms up, or feed back from the speakers due to a wiring issue. Either way, this is a hardware problem, and you shouldn't have this or any problem with the machine, especially with it only being 10 days old. Take it back for an exchange. Demand an exchange and don't let them give you the run around. When you get the new machine, you will see that you shouldn't have any problems with it for years to come. Also, don't let this bother you about Dell machines, they're one of the best machines on the market. Just like everything else, there are a few lemons.
Jul 25, 2008 | Dell Computers & Internet
Speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Jun 09, 2008 | Aiwa AV-DV75
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,.....it's happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
Pioneer VSX 915
Disconnect the speaker leads and see if this stops happening. If it does, connect up the speakers till the problem pops up, and that speaker that makes the problem happen is most likely bad. If the problems still happens with no speakers attached, then there is a problem in the audio output amp, and is going to need service , Good Luck
Jun 15, 2007 | Pioneer VSX-915 Receiver
Motorola Mobility MOTOROKR E6 Logo
20 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
