Question about Dodge 2010 Ram 1500 SLT/Sport/TRX
Heater does no blow out heat, and has a ticking sound in dash by the radio.
    Top Expert:
  • Dodge Master
  • 21,873 Answers
Probably a blend door issue. Either the door is stuck or the small activator motor is not connected to the door.
You might check to see if the truck is still covered by the factory warranty.
Posted on Jan 11, 2013
My 95 thunderbird makes a ticking after it is started,it continues for about 5 minutes and stops. Also it happens sometimes when I turn on the air condition. The heater also will not turn on. What co
Heater does not come on for a few minutes on purpose. The system waits until engine coolant is warm so fan not blowing cold air on you. The ticking can be the heater waiting to get turned on (air door closed) if sound seems to be coming from dash. System should work right away if you use A/C though.
Oct 18, 2014 | 1995 Ford Thunderbird
2003 kia sorento heater blows warm air only while driving at high speed
Engines can rock on the motor mounts. You probably have a vacuum line that is pinched, cracked, broken,kinked, or unhooked. check the engine compartment lines first. If you have thin plastic vacuum lines, they can kink more easily than rubber lines. If you have been working under the dash (replacing a radio, etc) check your work area in case you have a broken fitting on a vacuum housing or an unhooked line.
Dec 12, 2011 | 2003 Kia Sorento
Hi ! i have a 2002 x type that has over heated and there is also a ticking sound coming from underneath drivers side dash board?
The ticking sound, sounds like a relay, it's a small electro magnet type switch this could have been controlling the fan or heaters, if this has gone the car would overheat and make the sound.Get the relays checked before going any further. It should be cheap enough.
Hope this helps
Regards
Dan
Jan 25, 2010 | 2002 Jaguar X-Type
2003 Ford Exployer-Heater only blows cold air and theres is a ticking noise coming from my dashboard.
Sounds like a jammed air diverter gate or the coolent diverter valve. The ticking sound is the actuator trying to open the gate or the valve.
Nov 30, 2009 | 2003 Ford Explorer
A/c blows from floor
sounds like two problems. the ticking sound is probably a broken blend door stop. the wet floor is probably a bad heater core, both require dash removal.
May 20, 2009 | 2001 Cadillac DeVille
2001 malibu-heater is blowing cold air
sounds like you have a bad temperature sensor in dash or the cable has eitehr broken or come off the heater switch under the dash!!
Dec 07, 2008 | 2001 Chevrolet Malibu
No hot air FROM HEATER inside 2000 318IA
Hi There, If the fan blows only cold air, then you might have a restriction on the heater core. The heater core is like a small radiator inside your dash. The coolant flow through it can be restricted by corrosion. The lack of flow of coolant through the heater core will result in a lack of warm air inside the car. Flushing out the heater core may help. If not, you will have to replace it. I would say though, 80% of the time the cause is just restriction. Get the heater core flushed and I am sure you will get your heat back. MIke
Nov 05, 2008 | 2000 BMW 3 Series
Heater blows cold air
the electric motor that open the heat door looses electrical connection there by the door stays on cold / it is located under the a/c heater assembly / which requires removing the whole dash and heater assy// also bleed all air out of coolant system
there are three doors / 1/ a/c heat 2/ mode /defors 3/ recurculation dodgeboy6069@yahoo.com
Jul 19, 2008 | 2004 Jeep Wrangler
Dodge 2010 Ram 1500 SLT/Sport/TRX Logo
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
