Question about Dryers
Need help on fix White-Westinghouse electric dryer
The Model is:WDE546RBW1
I tried to replace the worn ball bearing. During the repairing process, by mistake, the wires attached to the heat element was pulled and somewhat damaged: there are 3 wires near the heat element connectors: 1 thick black one; 1 thick yellow one; 1 thinner darker yellow one (maybe  it should be called tan or dark yellow?). I know where the thick black one and the thick yellow one connect to the heat element connectors. The problems is: there is one thinner darker yellow wire - I don't know where it was pulled from? It seems it was pulled from the thick yellow one on the heat element connector. I need confirmation. (scary stuff!)  I took a photo: you can view it by clicking
 https://mywebspace.wisc.edu/hzhuang/DSC00161.JPG
Thank you in advance!
Kristin Bagne, Madison,WI
  • 2 more comments
  • saukcty32 Jan 22, 2009
    If you can't view the picture link above by clicking it, please copy and paste the URL  on your browser, it should show up. Thanks.
    I posted a comment, you can copy and paste  https://mywebspace.wisc.edu/hzhuang/DSC0... on your browser window and view the picture. Your solution will be appreciated. Kris
    I paid you via paypal. Please help. Here is the question:
    http://mywebspace.wisc.edu/hzhuang/DSC00...
    Hey, Thanks for the speedy response! I will try it after get off work. Out of curiosity, what is the "thinner, darker yellow" wire for? why is it attached to the heat element? Thanks again!
    Sergeant:
  • 367 Answers
Try this diagram see if it helps you. I apologize for the quick answer but I am having some issues on this end as well. I am sending this from my blackberry.
Posted on Jan 22, 2009
  • Rob Houg
    Rob Houg Jan 22, 2009
    The tan looking wire should be soldered to the yellow wire.
  • 10,594 Answers
Both yellow wires on same points as marked in below picture.
  • Shahid Electronics
    Shahid Electronics Jan 23, 2009
    Thinner wire seems feedback to control circuit.
    Genius:
  • 1,550 Answers
The message is page cant be displayed do upload in any other site .
You can also insert picture directly here.
  • SAM ANDERSON Jan 22, 2009
    Yes you are correct it is pulled from the thick yellow one on the heat element connector .
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
The dryer is making a loud scratching noise while driving
Your dryer uses nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Here is a video at this will walk you thru the replacement and inspection of the front bearing and glides. It may be a different model but the process will be the same. The blower wheel is another common place to hear noise and this is easy to check and inexpensive. The idler pulley is another part that frequently fails. Your dryer supports the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. All of these parts are inexpensive and easy to replace. There is a video of this also at the same site. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Sep 17, 2010 | GE DBSR453EBWW Electric Dryer
Dryer repair
The ball gets bolted to the drum first. Then the white bearing gets installed on the back of the dryer. Then It all goes back together when you install the drum into the dryer.
May 04, 2010 | Frigidaire GLER341A Electric Dryer
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
My hotpoint cdt00 tumble dryer makes a loud banging noise on each rotation what is causing this
It is probably a worn rear drum bearing, remove cover of drum shaft, and examine the drum shaft for wear.
Jan 17, 2010 | Hotpoint Dryers
Making a terrible loud squeaking problem like a belt is too tight or something....
Hello, I think by your description it's likely the rear drum bearing & hub. It is quite common on frigidaire/white westinghouse made dryer's.**unplug the unit before servicing** Try and search for a tiny little ball bearing at the back of the unit and see if you can isolate the noise is from there. If so you may be ok with some hi-temp silicone based lube for now, (you'll need to apply it from inside anyway, so you might as well replace it) but the bearing assembly probabely needs to be replaced...if that is the source of the squeaking. I hope that helps, Good Luck :)
Oct 29, 2009 | Frigidaire GLER341A Electric Dryer
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Aug 18, 2009 | Maytag Dryers
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
