Question about Denon S-101 System
Denon S-101 hissing sound in one speaker. Flat sound overall
It was a great system. I am not sure what exactly happened, but sound became very flat. You barely can hear any trembles. There is a hissing sound comming from one of the speakers
SOURCE: No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Posted on Apr 02, 2007
SOURCE: Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Posted on Aug 27, 2007
  • 93 Answers
SOURCE: Denon Home theatre System
If TV has AUDIO OUT and you hook up AUDIO OUT from TV to AUDIO IN on your system, it should play.
Posted on Oct 08, 2007
SOURCE: How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Posted on Oct 17, 2007
Drummernick
  • 440 Answers
SOURCE: neen instructions on my denon s-101 system
www.denon.com they have one if not on ther site please email there ther tech dep request manual in a pdf file in email ok they will take care of u i dont see any online justto show u
Posted on Feb 03, 2008
"hitachi 42PD8700U FLAT TV HISSING SOUND THROUGH
Check and replace its audio output IC.
Aug 03, 2013 | Televison & Video
Speaker crackling and switching on and off.
Sounds like you have a bad speaker wire or bad connection at a terminal, either at the speaker or the receiver. Check to make sure the wires are properly inserted into the terminals at both locations. If that doesn't work, start at one end of the speaker wire and wiggle/twist it as you go the length of the wire. If that doesn't find the problem, it could be a bad connection either in the speaker or the receiver. Good luck!
Apr 25, 2011 | Denon S-101 System
We have a denon avr-589 5.1 system. It worked great until my son tried to hookup the wii into it. We now have no sound on the tv and dvd player. He normally plays the wii through the samsung flat screen...
foxtile,
How funny my son just did the same yesterday!
Make sure that the speaker selectors and the input modes are set correctly. He must have hit both buttons at the same time which turned off the speaker outputs and changed the input mode to a setup we were not using.
-Chris
Jan 09, 2011 | Audio Players & Recorders
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
M-Audio BX5a Speaker Problem
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Sep 17, 2008 | M-Audio BX5a Speaker
Controlling the Bass Levels on a Denon AVR-684
http://www.manualnguide.com/download/manual-guide/denon-avr-684-av-receiver-owners-manual.html.
look for page 34 in manual above-sure you can reduce the bass overall.
Jul 18, 2008 | Audio Players & Recorders
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Neen instructions on my denon s-101 system
Feb 03, 2008 | Denon S-101 System
Oct 06, 2007 | Denon S - SERIES PREMIUM HOME THEATER...
Denon S-101 System Logo
21 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
