Question about Food Processors
Moffat Cuisine 300 guide
Lost guide
Where Can I buy a bowl and lid for my Magimix Cuisine Systeme 300 and are are there any shops in Western Cape that sells spare parts?
Since I don't know what country you are asking this question from ( I am in Canada), I recommend you do a Google search for "magimix cuisine systeme 300 parts" . I came up with this site of many http://www.magimix-spares.co.uk/Cuisine-systeme-3000-spare-parts-accesesories-stocked/products/1095/
You can even search eBay
Oct 25, 2015 | Magimix Food Processors
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
Unable to use magimix cuisine system 4100 given to me by my sister which has no manual.
Get in touch with www.magimix-spares.co.uk
This is a family owned firm which specialise in everything for Magimix.
BBS Ltd., Unit B
Grovebell Industrial Estate
Wrecclesham Road
Farnham, Surrey
GU10 4PL
England
Dec 28, 2010 | Magimix 4100 Cuisine Systeme 1268 Cups...
Dead motor in Magimix Cuisine 5100
Remove and check if there is any fault of a brush contact or switch contact or if the load trip switch had reset.
If the power is coming to the motor and is not running you need to confirm fully if the windings are open , if so replace motor.
if not remove and reset the setting of the brush/commutator.
Sep 24, 2010 | Magimix 5100 Cuisine Systeme Food...
How to slice carrots
Stack 4 of them vertically and feed into chute
Jun 05, 2010 | Magimix 5100 Cuisine Systeme Food...
Need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Oct 30, 2009 | Magimix 5100 Cuisine Systeme Food...
Magimix sytem cuisine
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Food Processors Logo
43 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
