Question about Panasonic KX-T7730 Corded Phone
Number of rings before going to voicemail on KX-T7630
My calls are going straight to voicemail. I want the phone to ring and only go to voicemail if busy or unanswered
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Posted on Jan 22, 2009
KX-T7710
The KX-T7710 isn't an answering machine. The ring count is controlled by the answering machine or voicemail system connected to the phone line. Could you tell us the make and model?
Nov 21, 2013 | Panasonic KX-T7630 Corded Phone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
How do I get my panasonic kx-t7630 to ring more than 3 times before going to my voicemail?
If you've set call forwarding from the set, try dialin *713 and a 2 digit number from 00-99. It's the number of seconds before the call forward and a ring cycle is approximately 6 seconds, so start with 24 and go up from there.
There's another feature that will work against you, and that's the transfer recall time. It may be set to 20 seconds, so you will never forward before the recall timer. It's set on a systemwide basis.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Calls go directly to voicemail
You have a FWD/DND button on the top of the phone. Press it and read your display. One of the choices is FWD with a destination displayed, one is DND, and one is Fwd/DND Off :-)
If you don't have DND set, it will only toggle 2 actions.
You can change the time/destination by using the *7104 xxx # where xxx is the voice mail system. 7104 is the CF No answer code (5 being busy/no answer and 2 being all calls and 3 is busy alone). *7100 clears it all.
In case you wonder what happened to *7101...it's Do Not Disturb.
Carl
Sep 24, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 cannot ring 1800 or 1300 numbers. Telstra can ring 1800 & 1300 numbers by-passing the PABX and plugging straight into the ISDN NT1. Suspected programming problem with system. Please...
Not knowing your complete dialing plan makes it difficult to figure out why you can't "ring" a certain number. What do you get? Can you call local? Is 1800 or 1300 a local or "free" call or is it long distance or premium? And, do you get bounced with a display that says something after you dial 1800 or do you have to dial a complete number.
These are all installer questions. It would be well beyond the scope of a public forum to do someone's restriction tables.
Carl
Sep 04, 2008 | Panasonic KX-T7630 Corded Phone
Outside calls are going directly to voicemail
there should be a switch at the side of the phone that controls this.
you need to set the amount of rings u want before it goes to voicemail.
sam !
May 12, 2008 | Panasonic KX-T7630 Corded Phone
RNGOFF KX-T7630
press the button below the readout "rngoff", let go, then rotate the volume control dial. It should raise the volume. The readout will now say "ring"
Jan 11, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
2,525 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
