Question about Generic Laundry Parts Generic Part GEM-627 Dryer IGNITOR - Replacement Comml. Generic Laund
What led among 1,2,3,4,6,8 receives 24 volt
    Top Expert:
  • 21,873 Answers
I see you posted this in a couple of different sections.
Did you get the new wiring harness and spark plug wire with the module ? The old spark plug wire is soldered to the box.
The wiring harness kit comes with the instructions.
You also get a package of cigarette connectors to modify the new harness to fit the old wires.
Posted on Jan 11, 2013
How do I properly determine the power supply of a parallel circuit of LED lights? I have 30 LEDS to wire into a large model. I know the individual LEDS each run on a 3 Volt CR2016 watch battery. I
You can go from 2 aaa'a three two D's depending on how long you want the battery's to last or project size. Depending on LED model 98% don't matter on the amps just the voltage. I was using 2 D's so you would have about 24 - 36 hour straight on time.. But if you could afford 4 of them for testing. Run four in line so the voltage will be 12 volts total and hook it up to your car battery and you should/would have a light for 6 months to a year and the LEDS should be just fine.
Sep 18, 2014 | Cars & Trucks
Is this unit avaliable to be used on 12 volt and 24 volt vehicles
Yes as long as you use the original garmin charger that comes with it. The garmin charger steps down either 12 or 24 volts to match the 5 Volt required input voltage of the satnav.
May 05, 2011 | Garmin nuvi 250W GPS Receiver
Power to Motherboard but will not bootup?
most likely a failed hard drive as all of the boot requirements are on it
Apr 24, 2017 | MSI 694T PRO (6309-470) Motherboard
WHAT TEST CRITERIA CAN I USE FOR THIS PACK
This thing is a beast! What criteria you ask? What do you want to jump? The answer.... any damn thing you want!
3200 peak amps is huge.
1600 peak amps is huge! You have got it covered here friend.
  • 3200 peak 12 Volt amps.
  • 1600 peak 24 Volt amps.
  • Integrated voltage selection switch.
  • LED battery status indicator.
  • Automatic recharging.
  • 60" Heavy-duty cables.
  • DC outlet to power a variety of 12 Volt accessories.
Sep 26, 2009 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mitsubishi WT-46807 Dead
Does the led light up when power is pressed? If so press menu and input buttons both in together to see if the led will blink a two digit error code then let me know the results. Please respond to this same post.
Jul 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubushi WS 65511
Good Day, TSIRS; Try all of these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 1. Check for 12 volts DC (AC-off detect) at pin 3 of PC9A21, if missing replace PC9A21 part # 268P058020 on the Power PCB. 2. LED does not blink at plug in. Check for 5-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P089010 on the Control PCB. 3.LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, if the supplies are correct suspect a problem in the DM Assembly (part # 955C230002) 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-76 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 4.7 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D587002 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 935C978002. Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Generic Laundry Parts Generic Part GEM-627 Dryer IGNITOR - Replacement Comml. Generic Laund Logo
64 people viewed this question
Top Generic Laundry Parts Dryers Experts
Dan Webster
Dan Webster
Are you a Generic Laundry Parts Dryer Expert? Answer questions, earn points and help others
