Question about Pioneer CDX-P1280 12-Disc CD Changer
Pioneer cdx P1280 error11
I was playing a disk and decided to change the disk. The player stopped playing and error 11 shows up on the player. Anyone ever hear of this?? I can't find anything.
  • amos olik Nov 07, 2007
    mechanism error
    aligning the mechanism
  • 32 Answers
Pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Posted on Jul 04, 2007
SOURCE:
Hi,I have had this Pioneer CDX FM67 mounted on my bike for 5 yrs and it always played good and showed no problems.This year every time I load some cds in the player nothing happens and then I get an error...
It relates to the failure of the loading section. So check on the linking wires/flexible strip to the load motor- this is a ccommon fault and is seen most of the time.
Secondly the tray with CD can get strck due to a faulty disc- being warped. if so manually retrieve and reset.
finally there is a tiny hole near to the eject which can reset the changer if this has hung up or is jammed.
Open the covers and probe.
Jul 17, 2011 | Pioneer CDX-FM687 6-Disc CD Changer
I get the message "error 11". What does it mean?
Error 11 is disk dirty, disc scratched, or mechanical failure. Try a lens cleaner. If that does not work, the CD player is bad.
Hope helps.
Mar 25, 2011 | Pioneer CDX-FM673 6-Disc CD Changer
I get a error ll message on my Pioneer CDX-P1280 cd player what does that mean and how can i fix it?
it maybe a programing problem in one of your programable chips that controle that erea if its new send it back and get a new cd player and also contact pioneer service center thier realy great and will help you
Jul 09, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
PIONEER CDX-FM65 PLEASE SCHEMATIC!!
err11 right? causes are either-
1/ dirty, scratched or upside down disk
2/ electrical or mechanical system fault
solution for number 2 from pioneer is
Turn the car ignition off and on again, or press power on/off button on the display unit and start the cd playing again
and one more thing to do is to open the door to the disk changer and bottom right you have a reset button press that then try again :)
These are the only thing err 11 can be with this model
Hope this helps you
Upfront Audio
Please rate and leave feedback thanks :)
Apr 17, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
CDX-FM65????? DOES IT EXSIST???
CLICK HERE for the specs on the CDX-FM653
No manual is available from pioneer for download.
ERROR 11 on pioneer cd players is common.
It can be due to a failing laser or dirty lens. It means that the CD was not recognised, either because of the CD scratched, or it could possibly mean the laser is out of alignment.
If the player works fine with other discs - chances are it needs a good cleaning.
If the player wont read any discs - it's time for a service call. Typically - I charge $50USD for clean and alignment.
you can do it yourself (clean it) by disassembling the player, and using a qtip and isopropyl alcohol - however an alignment requires a special alignment tool.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 16, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
CDX-P1280 multi disc unit locked up
THIS UNIT HAS A SEPERATE TWO WIRE PLUG AT THE BACK OF THE CHANGER WHICH POWERS IT, MAKE SURE THERE IS 12VOLTS GETTING TO IT
Dec 02, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CDX-P1280 12-Disc CD Changer not working,
sure............give the details of your problem and we will solve it
Nov 01, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Pioneer CDX-P1280 12-Disc CD Changer Logo
400 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
