Drive belt for akai audio gx-77
Circumference of belt is 55 cms. width of belt is 4 mm
  • 1,175 Answers
Use the "parts finder"
Posted on Feb 09, 2009
What is the difference between tire size 255/70 and 265/70
Hello Projocs03,
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire >Search Tires Tire 1 - 255/70R17 >Search Tires Tire 2 - 265/70R17 >Search Tires Section Width: - - Section Width: 10.03 in 255 mm Section Width: 10.43 in 265 mm Rim Diameter: - - Rim Diameter: 17 in 431.8 mm Rim Diameter: 17 in 431.8 mm Rim Width Range:
Rim Width Range: 6.5 - 8.5 in Rim Width Range: 7 - 9 in Overall Diameter: - - Overall Diameter: 31.05 in 788.67 mm Overall Diameter: 31.60 in 802.64 mm Sidewall Height: - - Sidewall Height: 7.02 in 178.30 mm Sidewall Height: 7.30 in 185.42 mm Radius: - - Radius: 15.52 in 394.20 mm Radius: 15.80 in 401.32 mm Circumference: - - Circumference: 97.54 in 2477.5 mm Circumference: 99.27 in 2521.4 mm Revs per Mile: - Revs per Mile: 669.8 Revs per Mile: 658.2* Source
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
Good luck
May 25, 2011 | 1997 Ford Expedition
Can 215/65/16 tires on a 1999 Caravan be swapped for 205/60/16 tires?
Yes, you'll be o.k. They don't recommend anything over 3% difference, and your at about 1.8%. Speedo will read 61 mph when actually doing 60 mph. Have a look.
Stock Tire - 215/60R16 >Search Tires Tire 1 - 205/60R16 >Search Tires Section Width: 8.46 in 215 mm Section Width: 8.07 in 205 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 5.5 - 8.5 in Rim Width Range: 5.5 - 7.5 in Overall Diameter: 26.15 in 664.21 mm Overall Diameter: 25.68 in 652.27 mm Sidewall Height: 5.07 in 128.77 mm Sidewall Height: 4.84 in 122.93 mm Radius: 13.07 in 331.97 mm Radius: 12.84 in 326.13 mm Circumference: 82.15 in 2086.6 mm Circumference: 80.67 in 2049.0 mm Revs per Mile: 795.4 Revs per Mile: 809.9 Actual Speed: 60 mph 100 km/h Speedometer1: 61.0 mph 101. km/h Speedometer Difference: - Speedometer Difference: 1.822% too fast Diameter Difference: - Diameter Difference: 1.8%
Nov 07, 2010 | 1999 Dodge Caravan
Need belt routing diagram for 1990 dodge cummins without a/c and also belt size
Here is what you need, hope it helps
# Serpentine Belt Ribs : 8
Belt Angle : 40 Deg
Outside Circumference (in) : 64.305"
Outside Circumference (mm) : 1633 mm
Top Width (in) : 1.087"
Top Width (mm) : 28 mm
Feb 03, 2010 | 1991 Dodge Ram 350
Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
Sep 09, 2008 | Audio Players & Recorders
Akai gx-77 real to reel
Mechanism is in need of major cleanning and lubrication. You might also consider replacing belts and rubber pulleys
Jul 12, 2008 | Audio Players & Recorders
Akai Gx-77 reel to reel tape dech
Good day fixya, thanks to take care of called, the problem I have not solved it then I do not have at the hand a supplier of spare parts, that can offer to a motor for deck gx-77 me of akai Please to provide the contact to me for such aim. If he is not inconvenient favor to then go to the attached mail in Spanish language nonhandling the English language To the attached equal them, the photographic file of the apparatus Thank you very much, RICARDO MARTINEZ CARDONA Cel 3177339950 Manizales Calda Colombia
May 27, 2008 | Audio Players & Recorders
Unable to record with Akai GX-77
Make sure the cassett you are using has safety tab intact. Clean the heads and tape drive roller. If unit has a record level control, make sure it is set correctly
Apr 07, 2008 | Audio Players & Recorders
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Nov 14, 2007 | Audio Players & Recorders
204 people viewed this question
