Question about GE JVM1630 Microwave Oven
Ge 1640 lights work but does not turn on
Lights are on but it does not turn on
  • GE Master
  • 17,129 Answers
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Posted on Jan 12, 2013
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile microwave just stopped working doesnt light up or turn on model pvm2070dmbb
You should first check the outlet with a toaster or hair dryer to be sure it's working under a load.
Then you should test the fuse then the TCOs.
There is a technical sheet hidden behind the grille or controls.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 26, 2013 | GE SpaceMaker Microwave Ovens
Are there any recalls on GE microwave JVM1540DN1ww Thanks, ssi96@aol.com
There are no recalls on GE over the range microwave JVM1540DN1WW but there SHOULD BE! Mine lasted only a year and a half and then started running and heating with the door open. Shortly after that it stopped heating at all. The light and fan works, and the keyboard lights up but the turntable doesn't turn anymore (yes I made sure the turntable was turned on), and it doesn't heat. It will count down like it's heating but it doesn't heat. Changing the door switches didn't work. Husband thinks it is the magnetron which is expensive to fix. I won't ever buy another GE microwave period! Check the web and you will see all the similar complaints. I just searched online and for a lesser price than I paid for the GE, Samsung sells one that has the one year warranty but also has a 10 year warranty on the magnetron.
Jan 25, 2010 | GE Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
My GE XL 1800 is making a huge racket. It still
I had the same problem. You need to replace the turntable motor. I used a local appliance repair shop and they charged $45 for the motor plus $65 labor(a house call). I just checked with searspartsdirect.com and they have the motor(part # WB26X10038) for $22.27. Oh well, at least it works.
Mar 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JVM 1640 BB - Spacemaker
ARE THE LIGHTS WORKING WHEN YOU OPEN THE DOOR?
DO THE CLOCK WORK? IF YES YOU MAY HAVE A BAD
TRANSFORMER,DO THE LIGHTS GO WAY DOWN WHEN YOU
HIT THE START BUTTON? YOU ALSO MAY HAVE A BAD CAP.
(DO NOT FOOL AROUND IN THIS PART OF THE OVEN)!!!!
BECAUSE MOST TRANSFORMERS PUT OUT ABOUT 2200VAC.
YOU CAN AND WILL BE KILLED IF YOU MAKE A MISTAKE HERE. IF YOU NO NOTHING ABOUT HV. STAY AWAY!!!!!!!!!
Jan 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE JVM1630 Microwave Oven Logo
22 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
