Question about Ovens
Circuit diagram for defy gemini gourmet oven - Ovens
5 Suggested Answers
SOURCE: i have a defy gemini petit chef multi function
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Posted on Jun 21, 2010
  • 552 Answers
SOURCE: The bottom oven of my
there is a thermal fuse on these units that trips, you will need to replace the fuse to fix the issue. Depending on the serial the fuse could be on the back or between the grill.
http://www.appliancerepairlesson.com/
Posted on Mar 01, 2011
reyjoshua07
  • 1157 Answers
SOURCE: nderwilt@telkowiring diagram for defy 600
Hi dvanderwilt,
For this concern, you need to contact Defy directly since they are the only one who can provide you the wiring diagram for this specific model. For contact information please visit this link. For additional information about your machine you may also visit the link below.
Defy 600
Hope it helps.
Thank you for using FixYa.
Posted on Apr 11, 2011
FitzOriginal
  • 842 Answers
SOURCE: I bought a house with a Defy Gemini Petite Chef
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Posted on Jul 08, 2011
My defy double door gourmet thermo oven overbakes cakes on the outside what should i do to ensure even baking
Reduce the temperature slightly or get an oven thermometer and follow the recipes.
Aug 01, 2017 | Ovens
Wiring diagram for gemini gourmet multifunction thermofan
Request the wiring diagram directly from Gemini.
Feb 09, 2017 | Ovens
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
My Defy Gemini oven does not heat up beyond 80 degrees C when on conventional baking? What could be the problem?
Check to see if the thermostat is plugged in under the cover inside left of door
Dec 03, 2014 | Ovens
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Apr 12, 2014 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Jul 08, 2011 | Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
Apr 01, 2009 | Ovens
Ovens Logo
482 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
