Question about Health & Beauty
How to clear memory? - Health & Beauty
  • 4 Answers
Knock yourself out adn hope you loose your memory
Posted on Jan 11, 2013
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
Hi & thanks. There is a small 'M' on the top center right of the 'number' screen. How do I get this to go away? Remove the battery? Thanks again & regards, -louis
This M does no harm. It merely reminds you that you stored something in memory. You can try pressing the AC (Clear All) button. Alternatively, store 0 in all the memories. If I am not mistaken you have 3 memories. Try
0 STO 1 to clear Memory 1
0 STO 2 to clear Memory 2
0 STO 3 to clear Memory 3.
Jun 29, 2011 | Texas Instruments BA Real Estate...
What does MC, MR, & MS mean?
Welcome to Fixya. Heres the meaning that you're looking for.
MC - Memory Clear. this clears all contents of the memory
MR - Memory Recall. This displays the current content in the memory
MS - Memory Save. This saves the current display to memory.
M+ - Memory Add. This adds the current figure to the value already present in memory.
Thanks for using Fixya.
May 12, 2011 | Office Equipment & Supplies
How to remove memory from scienfic calculator
To clear a memory location, just store 0 in it.
0 [STO] M clears memory M
0 [STO] A clears memory A
0 [STO] B clears memory B
etc.
Oct 13, 2010 | Casio FX-115ES Scientific Calculator
In use/memory light up and it won't let me fax.
To Clear the memory simply switch of the printer and power it on again. This will clear the data in the memory
May 25, 2010 | Office Equipment & Supplies
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
Memory full ux300
to clear memory(which i must warn will clear everthing) first press function then press the number 9,next press * (asterict) then press the number 8 then press the # key then 7 key, press start, you should see a ram version on screen,then press start again,next press # key untill it say's memory clear,press start and it should say memory clear.
Sep 23, 2007 | Sharp UX 108 Roll paper Thermal Fax
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
