Question about Belling Microwave Ovens
The turntable in my oven has stopped working
Model Belling STS17 (4) 055 1007328
  • Belling Master
  • 17,130 Answers
Possible that the motor has failed, remove the bottom and check for the voltage to the motor , is present the motor has failed, is not the board is faulty. check the belt drive.
Posted on Jan 12, 2013
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker Microwave Oven Model
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
  • 78 Answers
SOURCE: Turntable doesn't work at all
could be one of three things the turntable motor itself or the coupling maybe broken or the control pcb is not sending power down to the motor 1st see if you remove the coupling from the inside of the oven then put a cup of water in the oven and see if the motor is turning if yes then it might still be the motor as it might not be able to turn when it is under load look at the coupling close and you may see a crack down one side if not and the motor is not turnin then you can remove the motor you will need to the unit on its side on the bottom you will see an access panel this u will have to cut off to get to the motor it ok to refit ir you just turn it round and screw it back in place remove the motor and replace but if the unit has a pcb prob then you will need a meter to test A1 and 2 are worth looking into first thn think about if its worth it pcb`s are sometimes expensive hope it help dont forget to unplug it first
Posted on Oct 22, 2009
I have a High Pointe model EM925Bss-s and although the turntable does not work the oven still works. Is this dangerous?
no as long as you never put any metal or foil inside but food won't heat evenly , the turntable can usually be fixed by cleaning out center bearing with Q tip and a shot of oven cleaner this sometimes gets lots of food and grease build up from heavy use machines (usually mass food prep areas) and slows and stops the drive of turntable
Sep 10, 2014 | Microwave Ovens
I need a glass plate for a model mw820t do you have a spare parts outlet in new zealand or australia pls
Try Stokes for your parts.
http://www.stokesap.com.au/Content/templates/stokesap_product_stokes_detail.asp?articleid=62&zoneid=14 (then choose CONTACT)
Make sure you include the make and model number. This appears to be a Belling Microwave with a 305mm turntable that will fit Belling, Goldstar, LG and Thorn units.
LG Part No. 1B71018G (same as yours)
Listed on this page $54.01
http://www.diyparts.com.au/index.php?cPath=24764_24784&osCsid=a5f18b935b44e73627e35024ad34deaa
You may want to look up appliance parts in your local yellow pages and make a few calls looking for the LG part number above. $54.01 seems a tad on the pricey side.
Thanks for using FixYa.
Kelly
Mar 25, 2010 | Microwave Ovens
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
Oct 04, 2009 | Microwave Ovens
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Microve works but turntable comes & gos
If yours is intermittent or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can contact Belling customer service for more help.
Jan 02, 2009 | Belling Microwave Ovens
Belling microwave
Turn table motor open circuit/drive shaft damaged
Oct 18, 2008 | Belling Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
