Question about Dell Inspiron Mini 1012 Netbook
Dell Inspiron MINI 1012 Laptop Screen 10.1 LED flickers
I turn on and all that the screen does is flickers on and off then goes black. Restart and the same things happens all over again.
  • Official Brand Answer
  • 560 Answers
Soldbyajt,
It sounds as though the video card has gone bad in your system. There are a couple of things to try to eliminate the lcd.
If the LCD on the system shows no display or has other problems, here are some basic steps to take:
  1. If the LCD is not displaying any video, connect an external monitor to eliminate a no-POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  2. Connect an external monitor when possible for all LCD-related problems to help eliminate a possible software or video card problem.
  3. If the LCD has lines on the screen, check the system during POST as well as system setup to determine if the lines are present in all modes of operation.
    If you cannot get any video by connecting an external monitor then your motherboard will need to be replaced. The reason for the motherboard replacement is because your video card is soldered onto the motherboard.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
Posted on Jan 11, 2013
Maanita
  • 1142 Answers
SOURCE: Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
Posted on May 28, 2008
Geekman
  • 32281 Answers
SOURCE: Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 26, 2009
  • 10406 Answers
SOURCE: Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
Posted on Jun 15, 2010
  • 4 Answers
SOURCE: dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
Posted on Jul 24, 2010
  • 65 Answers
SOURCE: I have a Dell Inspiron Mini Laptop 1012, how do
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Posted on Jan 05, 2011
Where to get a cheap LCD screen replacement?
Try eBay. Do a search for Dell Inspiron Mini 1012 screen You will get results from $36 and up. I've never dealt with any of these particular sellers, but most of them have great reviews and I have used replacement screens for others computers that I purchased on eBay.
Sep 21, 2012 | Dell Inspiron Mini 1012 Netbook...
Need hdd password dell inspiron mini
I NEED AN HDD PASSWORD FOR MY DELL INSPIRON MINI 1018 MY SERVICE TAG CODE IS 2V2J2Q1
Jul 29, 2012 | Dell Inspiron Mini 10 N450
The inspiron 1012 does not seem to have an inverter. Is this true and if so where is it? The screen backlight is not working
Based on the instructions for installing a new screen here:
http://www.batterystyle.com/dell-inspiron-1012-screen-p-235410.html
There is an inverter. It's usually hiding under the plastic bezel around the front of the screen.
Sep 09, 2011 | Dell Inspiron Mini 1012 Netbook...
Dell Inspiron mini 10. The system will not boot up, after the Dell logo screen and blue bar goes away, the screen is blank and the curser is flashing in the upper left corner of the screen. F11 isn't...
That cursor indicated that the BIOS can't find an Windows installed on the hdd. Since even the recovery partition appears to be inaccessible the only thing left is to reinstall it using the recovery cd that should have come with it when you bought it If you don't have it you can order it from Dell.
Sep 01, 2011 | Dell Inspiron Mini 1012 Netbook...
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
The laptop screen will not come on. it shows the dell powerup logo then goes black. The monitor lights are on so it is getting power but it isn't showing anything on the screen
If it's a Mini 1012 there is a VGA (15 pin) connector on the left side of the laptop. You can try to connect an external monitor to see if you get a display. If you do, then your LCD display has a problem and needs to be replaced. If you have a Mini 1010 there is an HDMI jack on the right side of the laptop where you can connect an external monitor.
Jan 26, 2011 | Dell Inspiron Mini 10 Notebook
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
Dell Inspiron Mini 1012 Netbook Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
