Question about Rocketfish Rf-rbwhp01 Rocketboost Wireless Headphones
My Rocketfish Rf-Rbwhp01 Rocketboost Wireless Headphones play audio but it is choppy and not a consistent sound coming out of them. I have tried paring them to the hub and moving the hub to different locations. They dont seem to be transmitting well. pls help!
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
Rocketfish RF-HPL302 brand new. hooked up with everything off. first got great sound but video that was jerky &couldn't keep up. then just a green screen. now nothing even on the pass through hdmi
it seems like a component failure, I would send this back as dead on arrival. this can happen sometimes that shortly after switch on a component fails and the devices no longer works. you should follow up with your dealer under guarantee.
I hope this was useful.
Nov 16, 2014 | Rocketfish Audio Players & Recorders
How to fix a cut cord on a "rocketfish rf ca2e cassett adapter"
In the cassette is a little head, where the wires goto.
It is supposed to be two shielded wires, soldered on the head. The shield will be put together, to avoid extra hum and other noise.
If you don't have a clue, or you have to by a soldering iron, forget it, because on Ebay you perhaps find another adapter for only a few box.
Jun 17, 2014 | Rocketfish Lot Of 5 Rf-cpa3 Car Cassette...
Right head phone in op
It looks like you will need to open them up and look for a loose wire in both earpieces. Also, while there, check to see if the batteries are in correctly relating to polarity!
Jan 15, 2013 | Rocketfish Rf-rbwhp01 Wireless Headphones,...
How do I pair my RF-MAB2 to my Dell Latitude D620 Laptop?
Make sure your computer has a bluetooth radio (either internal/external). If it does, verify that you have the software to pair devices, such as Broadcom's software found here - http://www.broadcom.com/support/bluetooth/update.php
May 07, 2012 | Rocketfish Mobile Rf-mab2 High-definition...
How do I install rocketfish camera RF NBWEB without a disk?
Windows drivers are at
http://www.rocketfishproducts.com/skins/skin_1/Topics/Drivers/RF-Webcam.zip
Mac drivers are at
http://www.rocketfishproducts.com/skins/skin_1/Topics/Drivers/RF-NBCAM-Mac.zip
Feb 08, 2010 | Labtec Rocketfish Webcam
Where can i find the passcode for my rocketfish bluetooth adapter
Try 0000
most devices have a default code.
this one seems pretty common.
You can reset your code in most cases. Read the manual.
don't forget to rate me!
Jan 10, 2010 | Rocketfish Bluetooth USB Adapter...
Toshia Satelite sound skips when playing through speakers
From what I can tell your machine uses a Realtek sound device. Download and reinstall this driver to see if it fixes your problem.
Feb 24, 2009 | Toshiba Computers & Internet
Choppy audio playback
keep the headphones in one place - although that jack may be faulty
Aug 05, 2008 | SanDisk Sansa Clip MP3 Player
Rocketfish Rf-rbwhp01 Rocketboost Wireless Headphones Logo
20 people viewed this question
Top Rocketfish Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rocketfish Audio Player and Recorder Expert? Answer questions, earn points and help others
