Question about Whirlpool RF302 Electric Kitchen Range
HOW TO ADJUST temperature on model RF302BXGW
How to change the temperature on oven running to high
  • Whirlpool Master
  • 8,220 Answers
Swap out the thermostat.
Posted on Jan 11, 2013
Why will my kenmore oven only heat to 212 degrees after 2 houres?
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
May 28, 2014 | Kenmore Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool RF302 Electric Kitchen Range Logo
77 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
