Need to replace Model jcx-ts765, what is current model?
Need to replace current model?
NEED PART NUMBER FOR STIHL LEAF BLOWER MODEL BR380 FOR THE BACKBOARD PAD REPLACEMENT
Previous model PN 4203 790 8001
Current model PN 4203 790 8003
May 25, 2015 | Stihl Garden
I need the universal remote code for sanyo jcx-ts760 dvd player
There should be a code sheet that come with the universal remote when you bought it. What gives you the codes for the different brands.
Oct 17, 2012 | Televison & Video
I am a retired technician and want a service manual/schematic diagram for Sanyo JCXTS750 dvd home theatre receiver in order to repair it - do not want manual for DC-TS765
Hi Keith,
Sad to say that after checking my collection of service manual, I don't find this model number. I've also try to search for the direct link online but this in currently not available. I will inform you as soon as the manual is available.
May you please ask for a refund for this service.
Thank you for your patience.
Kind Regards,
Mjsazon
Nov 23, 2011 | Sanyo DC-TS765 System
I need to know what all cords do I need to hook it up right and how does the theater system hooks up to the tv?
I couldn't find the manual for this model but below is the link for a DC-TS760 Manual which should give you enough information to enable you to connect it all together.
Easiest way is to just use a Scart Lead (and Audio Leads if your TV has an Audio Out) as detailed.
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/DVD%20Home%20Cinema/DC-TS760UK.pdf
Please leave feedback
Cheers
Andy
May 09, 2011 | Sanyo DC-TS765 System
Hi.i have a sanyo dvd receiver model jcx-ts750 and now is playng only black and white.please help me.thanks
1. First make sure all you cords are plugged in correctly. (its better you unplug and plug the cords again as it is a simple way of resetting an elctronic gadget)
After doing step1 if you still face problem: try the following:
(May be the mode got changed:)
While 'DVD' is selected as the source and before playback
1) Press and hold SCAN MODE for 2 seconds.
The current setting appears on the display window.
2) Press Cursor Left/Right to select the desired
mode.
RGB: Select when your TV accommodates the interlaced RGB/composite video signal.
Y/C: Select when your TV accommodates the interlaced S-video signal.
You can get better picture quality in the order -"RGB" > "Y/C" > Composite.
3) Press ENTER while the selected mode
Regards,
BEADHZ
Jan 29, 2010 | Sanyo Televison & Video
I need a set up code for a universal remote for a Sanyo JCX-TS750 Cheers.
it depend on universal remote. Every remote has its own. Philips Universal Remote have 2462
Sep 15, 2008 | Sanyo Televison & Video
Washing Machines Logo
Top Washing Machines Experts
