Question about Kitchen Ranges
Ideal independent c24 fault code f1 - Kitchen Ranges
2 Suggested Answers
burty681
  • 56 Answers
SOURCE: ideal c24 mini combi boiler
and whats the problem??????????????????????
Posted on Jan 27, 2011
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Ideal heating boiler f1 fault
    Hi Janice, The link below is a short youtube video showing you how to fix error f1, Take care....CHEERS
    https://www.youtube.com/watch?v=o9wpeIvPOb0
    Mar 26, 2016 | Water Heaters
    I have a Suzuki GSX-R 750 and my F1 one light has started to come on when I excelerate some speed what does that mean.
    Odds are its your SET valve needing adjustment, have the codes pull on the bike. If it is the SET, you can remove the SET system easily or you can have it adjusted.
    If you get a code.
    The codes are as follows:
    C14 - THROTTLE POSITION SENSOR
    C15 - ENGINE COOLANT TEMPERATURE SENSOR
    C21 - INTAKE AIR TEMPERATURE SENSOR
    C22 - ATMOSPHERIC PRESSURE SENSOR
    C23 - TIP OVER SENSOR
    C24 - IGNITION SIGNAL #1
    C25 - IGNITION SIGNAL #2
    C26 - IGNITION SIGNAL #3
    C27 - IGNITION SIGNAL #4
    C28 - SECONDARY THROTTLE VALVE ACTUATOR
    C29 - SECONDARY THROTTLE POSITION SENSOR
    C30 - SECONDARY THROTTLE CONTROL UNIT
    C31 - GEAR POSITION SENSOR
    C32 - INJECTOR SIGNAL #1
    C33 - INJECTOR SIGNAL #2
    C34 - INJECTOR SIGNAL #3
    C35 - INJECTOR SIGNAL #4
    C41 - FUEL PUMP CONTROL SYSTEM
    C42 - IGNITION SWITCH SIGNAL
    C46 - EXHAUST CONTROL VALVE ACTUATOR
    C00 - NO FAULT
    Jun 28, 2011 | 2007 Suzuki GSX-R 750
    Ideal c24 mini combi boiler
    Jan 27, 2011 | Heating & Cooling
    F1 code on my 2006 suzuki gsxr. it just started an 2 hrs ago drove it home in 20 degree weather now f1 code and no start
    When the red light comes on, eg (F1) use these fault codes to find your problem. To extract the codes from the computer system, there is a two pinned connector hanging out of the wiring harness, on the left hand rear of the bike, (say above the pillion foot peg under rear trim. Be sure not to confuse the other connector used by the Suzuki Workshop Mechanics, as this has four or five wires to the connector) After locating the one with only two wires at the back, use a split pin or paper clip to bridge the two wires togeather and turn the ignition to the ON position. You should now be able to read the code on the console. The fault codes are as follows,,
    **** GSXR Fuel Injection (FI) Code List:*****
    C15 - ENGINE COOLANT TEMPERATURE SENSOR C21 - INTAKE AIR TEMPERATURE SENSOR
    C23 - TIPOVER SENSOR
    C28 - SECONDARY THROTTLE VALVE ACTUATOR C29 - SECONDARY THROTTLE POSITION SENSOR C30 - SECONDARY THROTTLE CONTROL UNIT
    Feb 03, 2010 | 2006 Suzuki GSX-R 600
    2002suzukigsxr1000,fuel injection giving fault code c26?
    This is normally a ignition signal fault ,and will usually be from an interrupted signal from your ignition coil which can give the code c24-c27.
    Check the coil,wiring/coupler connections and power supply from the battery.
    Aug 24, 2009 | 2002 Suzuki GSX-R 1000
    Missing instructions for setting timer on boiler
    if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
    if you log onto the ideal web site you should be able to download a copy of the programing instructions.
    Feb 21, 2009 | Water Heaters
    F1-6 Fault Code
    This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
    Maytag Gemini fault codes.
    Fault code Suspect area Fault code Suspect area
    F0 - 0 None
    F1 - 1 Runaway cook upper oven
    F1 - 2 Runaway cook lower oven
    F1 - 3 Runaway clean upper oven
    F1 - 4 Runaway clean lower oven
    F1 - 5 Keypad cancel upper
    F1 - 6 Keypad cancel lower
    F1 - 7 Keypad disconnected
    F1 - 8 Keypad shorted
    F1 - 9 Slave
    Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
    Kitchen Ranges Logo
    165 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
