Question about Stihl Bg 86c Handheld Blower Cylinder Bg86c
Br 400 spewing oil out the back
16 years old, lots of hours on blower, still seems to have plenty of power, spraying oil out the rear plastic housing, top of gas tank area. Are the cylinder rings worn out?
  • Stihl Master
  • 1,807 Answers
The only oil in the machine is that which is mixed with the fuel. If the machine is still running well with plenty of compression then i doubt it would be the piston rings. With the limited information i would say to check the exhaust gasket between the exhaust port and the exhaust itself. Sometimes these can degrade and dirty liquid can be blown out of the gap.
Posted on Mar 02, 2013
How to fix low beam headlights won't come on---hi beams work ok?
Kenneth, you need to give more details on what kind of vehicle, year, make, style and so forth so we can attempt to make a judgment on this.
Well did you try the solution?
Your headlights are an essential safety system for nighttime driving & visibility. If your headlights are not working, or are not aimed properly, you might not be able to see the road clearly.
Here are some suggestions on how to troubleshoot various kinds of headlight problems:
Problem: One headlight does not work
This usually means one of the headlight bulbs has burned out. Bulbs have a limited life that depends on the number of hours of use, and how much vibration they have been subjected to over time. The thin tungsten filament inside an incandescent headlight bulb will eventually burn out. The more nighttime driving you do, the sooner one or both headlights will fail. A typical automotive incandescent headlamp (halogen or regular) has a service life that may range from 600 to as much as 2000 hours of use. For the average motorist who drives 12,000 to 15,000 miles a year, that means replacing a headlight maybe every five or six years depending on how often the headlights are used. Driving on rough roads may cut that life short by causing the delicate filament inside the bulb to fail prematurely.
The Fix: Replace the burned out bulb.
But before you do that, inspect the electrical connector on the back of the headlight carefully for damage, and see that it is not corroded or loose.
The headlight bulbs on most vehicles today are changed from the back of the headlight housing. The housing is a sealed plastic shell with the bulb and socket mounted on the back. The socket that holds the bulb usually twist-locks into the housing. Rotating it counterclockwise about ¼ turn will unlock the tabs and allow you to pull the bulb and socket out of the housing. Access on some vehicles is easy, but on others you may have to remove other components that are in the way, or even remove the housing mounting bolts and remove the housing before you can change the bulb. See your owners manual or the vehicle service literature for detailed instructions on how to replace a headlight bulb.
Once the socket has been removed from the headlight housing, you can pull the old bulb out of the socket and replace it with a new one (must be the same size and style as the original bulb).
Aftermarket replacement bulbs with slightly higher wattage ratings and/or tinting are available to upgrade headlight performance and improve nighttime and bad weather visibility.
best regards,
daid
I ask you did you try the solution posted twice then?
Sep 28, 2015 | Cars & Trucks
The sewing machine was apparently used once for a small job and then put away. The next time it was to be used the hand wheel was found not to turn.
Sometimes, if the machine has not been used in a long while, the grease and oil can harden around the bearings and other metal moving joints. To get it moving again, a few drops of Triflow and a hot hair dryer aimed at the recalcitrant bearing while gently moving the hand wheel will start it moving. Just continue working on that point until it is freed up. A good cleaning would then be in order. I am assuming a vintage mostly metal machine for this answer, not a computerized electronic machine.
Jul 26, 2015 | Singer 2250 Portable Sewing Machine
How do I replace the linear ball bearing on a c8fb2 Hitachi miter saw
Its not too difficult:
1) There are 2 retainer pins located on the rear slide support (#4 on breakdown) - carefully drive these out with a punch - be careful to support the bracket so you don't break it.
2) remove the rear support and slide the saw head and arms out of the bearing.
3) Remove the 2 covers (front and rear) over the bearing
4) loosen the allen head set screw on the housing that holds the bearing in place
5) using a large socket and a plastic hammer - gently tap out the old bearing.
Reverse process to replace.
Do not use grease or oil on the bearing or slides - use a pure, clear silicone spray that dries completely - grease & oil attract & hold dirt and debris and will cause bearing failure.
Hitachi C8FB2 8 1 2 Twin Rail Sliding Compound Miter Saw Parts
Feb 14, 2015 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
Backpack blower will not shut off when knob is pushed to "stop". Have to disconnect spark plug boot to shut off blower.
Your off switch may be wet or disconnected. You can try spraying it with a little bit of contact cleaner or WD to clear the moisture. If this doesnt work you can pull a cover and trace back the wire and see if it just fell off or melted. Good luck and be safe!
Oct 04, 2014 | Stihl Br 320 340 400 420 Backpack Blower...
Car stalls in rain
You did not mention the year of your car so it is hard to answer. If it is old enough to still have a distributor then you may have moisture inside the cap. Pop it loose and spray with electrical contact cleaner or WD-40. Also look for cracks in the cap and/or damage to the seal at the bottom of the cap while you have it off. If you have any doubts about it replace it.
Feb 16, 2014 | Geo Tracker Cars & Trucks
Stihl br 400 problem- spewing oil out the back of motor
I would say it is not an issue with the piston and rings, any oil leaking from the muffler has to be unburnt oil from the fuel/oil mix, if not already you should run it at a 50-1 mix, also make sure the engine is not running too rich on the fuel screws, check the condition of the air filter as a blocked filter will richen the mixture.
Jan 11, 2013 | Stihl BR400 Backpack Leaf Blower
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Stihl Bg 86c Handheld Blower Cylinder Bg86c Logo
183 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
