Question about Megatech HorseFly RC Helicopter
Megatech.com Batteries fully charged. control stick on the left does not activate the rotor motors or trim controls next to it. Right side controls are ok. Front running LED on that circuit will not light. Looking for bad connection on the helo, but nothing is obvious. Any suggestions?
Last green light flashes
1 Flash The batteries need charging. Check the battery connections. If the battery There is a bad connection to the batteries. connections are good, then try charging the batteries. 2 Flashes There is a bad connection on the left motor. Check the left motor connections and wiring harnesses. 3 Flashes The left motor has a short to a battery Contact your authorized Pride Provider. connection. 4 Flashes There is a bad connection on the right Check the right motor connections and wiring motor. harnesses. 5 Flashes The right motor has a short to a battery Contact your authorized Pride Provider. connection. Rippling LEDs The charge inhibit has been activated. Make sure that the battery charger is not connected to the power base. 7 Flashes There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. 8 Flashes There is a control system fault. Check power module and joystick module connections and wiring. 9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode. 10 Flashes An excessive voltage has been applied to Check the battery connections. the control system.
or go here and find yours,if you would of given the info we need,i would of diagnosed it for you,but,you didnt Pride Mobility Products Corp Basic Troubleshooting Instructions
Apr 20, 2015 | Health & Beauty
Brookstone Helicopter Cloud DSS
In general, the main rotor in an R/C helicopter only tips forward and backwards of vertical center. Direction is determined by the tail rotor. If the entire machine is tilting right, even if the rotor doesn't appear to be, check the motor mount, and or gear train of the main rotor in the fuselage. The main rotor shaft in the fuselage should be exactly vertical relative to the helicopter deck and with trim tabs centered. If your model has the two small fans, one on either side of the fuselage, try replacing the propeller on the right one, even if it looks OK and check for lint or hair on motor shafts. Again, this is a general answer from my own experience. Hope it helps.
Dec 04, 2013 | Electronics - Others
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Dec 25, 2010 | Toys
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
I need instructional manual for tiger wood 08 pc dvd
Tiger Woods PGA Tour 08 (IBM PC Compatible) Instructions:
COMPLETE CONTROLS
GENERAL KEYBOARD CONTROLS
Alt Key = open pop-up menu
Control Key + M Key = return to main menu
Control Key + K Key = view scorecard
Control Key + L Key = view leaderboard
Control Key + O Key = options screen
Control Key + B Key = view caddie book
Control Key + S Key = save game
Left Arrow or Right Arrow Key = aim left or right
> or < Key or Mouse Wheel = select next club
[ or ] Key = select next shot type
Esc Key = skip ball flight, cancel shot
T Key = toggle trueswing analyzer on or off
M Key = take a mulligan (if enabled)
/ Key = bring up putter
P Key = enage practice swing (once to take a swing, again to step up and address yout ball)
CAMERA CONTROLS
W, S, A, or D Key = move camera forward, backward, left or right
F or V Key = move camera up or down
- or + Key = slow or speed up camera movement
1 Key = swing view
2 Key = ball-drop view
3 Key = blimp view
4 Key = green reading view
5 Key = ball cam forward to green
6 Key = low camera to flag
7 Key = tv tower tee box view
8 Key = tv tower greenside view
9 Key = side profile swing view
0 Key = opponent view
Control Key + E Key = camera editor
E Key = shot target camera
G Key = toggle grid on or off
O Key = toggle overhead map on or off
ONLINE GAMES
Enter Key = chat
GAMEPAD SWING CONTROLS
SETTING UP A SHOT
D-Pad = move targeting mark
5 Button (Hold) + Left or Right Analog Stick = control free camera
9 Button = watch the hole fly-by overview
10 Button = preview club yardage
6 Button = switch clubs
4 Button = change camera view
1 Button = select shot type
3 Button = zoom to targeted landing spot
2 Button = start swing
SWINGING
2 or A Button + Left or Right Analog Stick Down = begin backswing
Left or Right Analog Stick Up = downswing
Left or Right Analog Stick Back Diagonally + Left or Right Analog Stick Up = draw or fade the shot
PUTTING
Left or Right Analog Stick Up and Down = putting
TRUESWING
Mouse Back = backswing
Mouse Forward = downswing, follow-through
Esc Key of Left Mouse Button = interrupt a swing
Jan 01, 2009 | Electronic Arts Tiger Woods PGA Tour 08 ...
Megatech HorseFly RC Helicopter Logo
15 people viewed this question
Top Megatech Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Megatech Toy Expert? Answer questions, earn points and help others
