Question about Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz Intel Core 2 Duo 4 GB DDR3 320 GB SATA HD SuperDrive Notebook
Kodak ESP3.2 will not download software
Initially worked -got paper jam message , but no paper jam. The printer is stuck with message "press ok to continue" but it does not respond. Now brand new macbook pro will not install the printer software per mac. Says it is from an unknown source. So I have 2 problems now. One with printer stuck and not responding and 2nd, cannot download the software on my new mac.
SOURCE: MacBook Software Updater - continually prompts to install an update
You're probably not actually flashing the firmware, but downloading the utility to do so. Follow these steps:
1. Quit all other open applications. Open the MacBook Pro EFI Firmware update which is in your Utilities directory
2. Click Shut Down in the MacBook Pro EFI Firmware Update window and wait for your computer to shut down.
3. Press and hold the power button on your MacBook Pro until the power indicator light flashes repeatedly, then release the power button to begin the update.
A status bar indicates the progress of the update.
Important: Do not interrupt the update.
Your computer restarts automatically when the update is completed and opens the MacBook Pro EFI Firmware Update.
4. Click OK, if the firmware is now up-to-date.
Posted on Apr 29, 2008
VenturerX
  • 31 Answers
SOURCE: mac tuneup software compatible?
Ensure that your system is all up to date with System Updates and check the website where the program came from and see if anyone else if having any problems
Posted on Jan 01, 2009
arnomonfort
  • 115 Answers
SOURCE: mac tune up software
Use ONYX instead. Better and complete solution:
http://www.titanium.free.fr/
Posted on Feb 04, 2009
  • 183 Answers
SOURCE: Facebook will not load
Download the mac version of opera browser and see if that fixes the problem.
If it does, then simply use that or re-download safari from Apple's site.
Posted on Jul 25, 2010
scotti2477
SOURCE: Have a macbook pro and
This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
Posted on May 18, 2011
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Mar 18, 2009 | Office Equipment & Supplies
Kodak 5500 All In One Printer set up problem
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
Jan 02, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Paper jam
Paper jam means that the rotation of the roller is not smooth, either because you are not inserting the paper correctly or there is something stuck in the printer. What you have to do is open the back cover of the printer and check the roller and clean it. Then if still paper jam is there, then it's manufacturing problem. Contact manufacturers.
Dec 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz Intel Core 2 Duo 4 GB DDR3 320 GB SATA HD SuperDrive Notebook Logo
20 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
