Question about Dishwashers
How do I replace bottom door seal on Hotpoint Aquarius dishwasher model FDW70P
  • Janette Highlands Jan 12, 2013
    Already looked at this video but it appears to be a diffferent seal.
  • 17,130 Answers
Please check on this link for tips: door seal
Posted on Jan 12, 2013
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: hotpoint aquarius dishwasher
I too have a problem with oversudsing in my hotpoint FDL570, the engineer came out but he was useless and in denial, I use Finish tablets and have found that if you use just half a tablet AND A TEASPOON FULL OF COOKING OIL SOLVES THE PROBLEM.
Crazy thet you have to do this but it works and of course never buy Hotpoint again!
Posted on Dec 12, 2009
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
SOURCE: Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Posted on May 08, 2010
SOURCE: Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Posted on May 27, 2010
Replace door seal
its quite easy on this machine,you can view a video on Espares.co.uk or remove front panel ,seven screws 4 top 3 bottom unclip wire on seal at front seal has two large clips to secure one outer and one inner, I find it best once the front panel is loose to unscrew the door interlock to fully remove cover once this is done you can see the workings and the exposed seal good luck.
Nov 02, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My dishwasher keeps depositing this black gunk on my dishes when I run it lately
Hello......Have you checked on opening the door that the filters in the base of your dishwasher are really clean.....if so....then remove and check that your spray arms are clean and not blocked.......also check that the door seal has not started to perish .or break down....if so replace it....Finally run a dishwasher cleaning product through the washer at the highest temerature.......
regards Sir Galahad
Aug 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
