The motherboard of my hp nc6220 got burnt, what are the next steps to take to get it done
I'm assuming you want to change the motherboard, in this case you will need to disassemble the laptop and replace. If you don't do this you can cause serious damage to internal components like the CPU or video card.
Tutorial on how to open laptop and replace mother board
Part 1-http://www.youtube.com/watch?v=BehxoPcTiSs&list=UUNMQUIsr2FzAGQdrlnGYKGw&index=24
Part 2- http://www.youtube.com/watch?
v=FOj15IJZSaU&list=UUNMQUIsr2FzAGQdrlnGYKGw&index=23
Place to buy motherboards (model number can be on back or front of motherboard)-
http://www.amazon.co.uk/b?ie=UTF8&node=430512031
Posted on Jan 11, 2013
Disc read error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 12, 2013 | HP Compaq NC6220 Business Notebook
Hi, my hp compaq nc6220 switches on but the screen wont light up
Hook a external monitor to the video output on the back of the laptop, if monitor works, it means that the laptop screen has a bad inverter board or back light issue. If the monitor has a blank screen like the laptop, the video graphics card is bad, or you have motherboard problems, suggest a computer tech.
Jan 05, 2011 | HP Compaq nc6220 Notebook
I have nc6220 its tataly dead1.Removed bat no effect 2.tried with new psu no effect 3 ook out hd no effect 4Removed memory no effect 5 Removed all movable items no effect
By your description, is sounds like your motheboard is probably dead.
Buy a motherboard from ebay:
http://cgi.ebay.com/HP-COMPAQ-NC6220-Motherboard-w-1-73GHz-CPU-centrino-PM-/320500403724?cmd=ViewItem&pt=Motherboards&hash=item4a9f500e0c
Send it in for repair to a PC tech along with the motherboard
Jun 30, 2010 | Computers & Internet
Pls tell me how to remove the keyboard of compaq nc6220 laptop
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00622160/c00622160.pdf
CHECK THIS ... EXPAND REMOVAL AND REPLACEMENT PROCEDURES AND 6.9 KEYBOARD ... IT WILL GIVE YOU STEP BY STEP PROCEDURE AS IN HOW TO DO THE JOB.. GOOD LUCK
Jan 27, 2010 | HP Compaq nc6220 Notebook
Hp nc6220 power trouble
Simply put there can one of several causes. Test the power output at the tip of the charger, weak or failing chargers may not deliver the specified voltage to properly power or charge the laptop sufficiently to continue operation. The DC jack may be worn out and not accepting the proper voltage from the charger. A very hot charger may be an indication of power distribution issues. The biggie may be that the motherboard has failed and is not accepting the signal to keep things running and is ordering a complete unit shutdown before the boot process begins.
Sep 12, 2009 | HP Compaq nc6220 Notebook
Nc6220 PC Notebook won't boot up
Motherboard. Your best bet is to purchase another computer. If you can however get the motherboard at a cheap price, then go ahead and change it. I would check ebay first.
Aug 18, 2009 | HP Compaq nc6220 Notebook
How to remove the nc6220 touchpad
hi...you lock the side please be careful you only go left and upward..good luck and hopefully help me have you..
Jul 20, 2009 | Computers & Internet
Occasional freeze after startup
If it didn't make it through scan disk it is most likely the hard drive.
May 26, 2009 | HP Compaq nc6220 Notebook
Hp nc6220 not starting up
You could have a motherboard problem or faulty RAM modules.
Try reseating the RAM modules and the boot up the laptop or get the RAM modules tested at your friendly computer shop.
If this doesn't work, most you have a nice pape weight.
You could then salvage the hard drive and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 18, 2009 | HP Compaq nc6220 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
