Question about KitchenAid Professional 600 Series 6-Quart Bowl Lift Stand Mixer
KitchenAid stops working when anything other than liquid is in the bowl..
Our KitchenAid is only 2.5 years old. If we test mixing with just water in the bowl, it mixes. The minute we add any kind of flour or anything, the machine stops working. The motor is still running but the paddle/whisk etc will not turn. If anyone can help - it would be greatly appreciated. I'd love to fix it myself. :) Thank you!
    Novelist:
  • KitchenAid Expert
  • 185 Answers
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Posted on Jan 26, 2013
  • 9 Answers
SOURCE: KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Posted on Mar 25, 2008
ricardok45
  • 135 Answers
SOURCE: KSM5PS won't turn under load
Hi. Remove the top cover and look for the plastic transmission housing, it's toward the front of the machine. Look for cracks in this housing. If the housing is cracked, remove it and look for further damage to the worm gear assembly and the bearings and bearing seats that support them. You'll have to remove some of the grease to inspect the parts. If you're lucky, only the trans. housing will need replacement. If, like me, you're not so lucky, you may have to replace the housing, wormgear assembly, bearings and re-work the bearing seats so that the new bearings fit properly. Although Kitchenaid advertises that their mixers can easily handle bread dough, the truth is...They can't. This scenario happened to me and I had to replace all of the above. Be prepared to wait a month or more before your parts arrive. Specify that you want the METAL trans. housing. I'm still waiting (6 wks.), for a single bearing. If this solution works for you, please rate my solution. Good Luck! ricardok45
Posted on Jan 01, 2009
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
  • 234 Answers
SOURCE: Paddle is rubbing the bottom of the mixing bowl
It is going to low down. the adjustment should at the back of the unit.
Posted on Mar 14, 2009
  • 145 Answers
SOURCE: professional 600 - makes loud noise when
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Posted on Jul 08, 2009
Jeans mixer needs a check its less then 1 year old
Contact Peter McInnes or hop onto their web site
Jan 28, 2014 | KitchenAid Food Mixers
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
Beater hitting bowl. Very wobbly, won't stand still when
More likely the pedestal base is bent. Your local service agent has probably seen it before and should be able to bend it back flat again. It's a brutal process with a heavy soft hammer that you probably won't want to see.
Jul 15, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
I just purchase an Ultra Power Plus KitchenAid mixer ( 325 Watts). This is a sturdy and capable but there are two major drawbacks in comparison to my old Sunbeam Mixmaster. 1. The Sunbeam had two bowls --...
Wow. We at kitchenaid designed the unit for durability and very long life. The design brief was to build the sherman tank that whisks. You got it. A spare bowl may be purchased from your local supplier. Roller system ... no. It was considered but left the mixer "slippery ' On the bench so was discarded. Sorry. Happy mixing well into the future. See you for a service in 20 years.
Sep 18, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My Professional HD Kitchen Aid doesn't mix all of the ingriedienc
One thing many KitchenAid mixer owners complain about is that it's difficult to scrape the bowl while the mixer is running. Because the beater rotates around the inside of the bowl, and because the beater doesn't actually touch the bowl, you have to stop the mixer frequently to scrape the sides of the bowl to make sure all the ingredients are well incorporated.
Two companies have come up with fixes for that problem -- the BeaterBlade+ and the SideSwipe.
They are available for most KA mixers. Cook's Magazine tested both in January 2009 and liked the SideSwipe a tad more than the BeaterBlade because they thought it performed a little better on a particularly heavy cookie dough, but one reviewer on another forum commented that dough tends to bunch up on the SideSwipe's inner parts.
In any case, I have the BeaterBlade+, mainly because it was available from Amazon for $30, no tax, free shipping, and I didn't feel like driving around to find the other.
Both are made of very strong plastic and have silicone scrapers on the edges of the blades. The scrapers do touch the bowl and thus provide a constant scraping of the ingredients, assuring that everything gets mixed in. I've found that I rarely have to stop the mixer, except to make sure that the ingredients that cling to the beater itself are mixed in.
Jul 09, 2009 | KitchenAid Food Mixers
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
Jun 24, 2009 | KitchenAid Food Mixers
Mixing bowl is jammed into the base and won't come out
you may have the old style frame which is why the bowl jammed old bowls are no longer avaible you may need to purchace a new mixer
Dec 10, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
KitchenAid Professional 600 Series 6-Quart Bowl Lift Stand Mixer Logo
74 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
