Question about Audiovox Car Audio & Video
Audiovox 7 band EQ , has 12 wires , 6 are in plug 6 are not where do they go
Has a connector plug with 6 wires light purple , white , and blue, other 3 are light green , yellow and red . it also has 6 wire without plug theres a black , blue with fuse holder a brown and brown with blue stripe, gray and gray with blue stripe this is an older model EQ i dont see any model # just has audiovox
SOURCE: Automax 7 band car equalizer
hola, first have tranlate for spanish a english, mira yo tengo el mismo ecualizador, las entradas son (input) el rojo (red) es (+) y el negro (black) (-), el verde (green) es el canal izquerdo (left) y el gris (grey) es el canal derecho (right) eso es toda la entrada, los comunes o los negativos de las salidas del stereo no se conectan (las salidas del stereo tienen que conectarse como si fuera un sistema de solo 2 bocinas a la entrada del ecualizador), las salidas (output) serian azul (blue) comun izquerdo (L-),blanco (white) izquerdo frontal(+ front L), cafe (brown) izquerdo trasero (+ rear L), naranjo (orange) comun derecho (R-) ,violeta (violet) derecho trasero ( + rear R), amarillo (yellow) derecho frontal (+ front R)
para que quede mas claro
input:
red (+)
black (-)
green (L)
grey (gris) (R)
output
Right
violet (Rear)
yellow (Front)
orange (-) R comun
Left
brown (Rear)
wihte (blanco) (Front)
blue (-) L comun
ojala que este post aun te sirva, saludos desde Chile
Posted on May 30, 2008
kias
  • 25 Answers
SOURCE: help
red -power
black/casing - negative(ground)
orange-is memory/ignition on
the rest are right'left outputs
Posted on Sep 20, 2008
  • 28 Answers
SOURCE: pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Posted on Dec 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Posted on Jan 17, 2009
smartr10U
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
The following are the accepted standards for different trailer types.
The different plugs and connectors used are marked with either a number or letters. Having the functions of each in advance can save a lot of trial and error when troubleshooting..
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Dec 25, 2009 | GMC Blazer Cars & Trucks
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Jayco camper has 6-plug connector------car has flat 4-plug connector where do green,yellow,brown and white wires from car flat 4-plug connector connect to on yellow, blue,brown,red,green and white wires...
It would be easiest, and best, if you were to upgrade the cars' trailer connector. The 4 way just supplies brake, parking, turnsignal, and a ground. The colors are the same on the 6 way, but 2 lines are added, usually for a electric brake controller and aux. circuit. Be careful about using the battery line (Red) on the 6 way connector unless you are also upgrading the white wire to a heavier gauge (at least the same size as red).
Green - Stop and Right Turn Signal (4/5/6/7 way)
Yellow - Stop and Left Turn Signal (4/5/6/7 way)
Brown - Running Lights (tail, side, tag) (4/5/6/7 way)
White - Ground / Negative (4/5/6/7)
Blue - Electric Brakes (5/6/7 way)
Red - Aux. charge line for emergency break away, battery charger, etc. (7 way)
Purple - Aux. backup lights / other purpose (7 way)
Aug 16, 2010 | Electronics - Others
Wiring diagram, sony cdx 3100 car cd player
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
Feb 24, 2010 | Car Audio & Video
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
This is looking at the connector with the wires towards you.
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
1 2 3 4 5 6 7 8
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
Dec 22, 2008 | 1995 Ford Windstar
Car Audio & Video Logo
49 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
