Error 50.6 in hp laserjet 9500hdn - Office Equipment & Supplies
    President:
  • 1,952 Answers
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Posted on Jan 22, 2009
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
Hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
Hp laserjet 9500 is showing error 59.6k. and asking for restar.after re start error is same pls solve this issue
59.6K is a problem with the black image drum.
Take the black cartridge out of the printer. Shake it, reinstall it. Power cycle the printer. If the error comes back, remove the black image drum and reseat it. The image drums(one for each color) sit below the toner cartridges.
If the error still comes back a tech is going to have to look at the printer.
Apr 04, 2011 | HP LaserJet 9500hdn Printer
I have an HP Color Laserjet 9500hdn and I use the HP Universal Printing PCL 5 (v5.0) driver. The problem is that I cannot print in color, nor do I have any color options in the preferences. Any help is...
Try installing the Lasjet 9500 printer driver.
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Feb 03, 2011 | HP Color LaserJet 9500HDN Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
Can't find what displayed error message means
This is normally down to the information or data if you will that you have sent to the printer. Delete all in the print que and restart the printer.
If this doesn't work then tun the printer of and remove the additional memory. Turn on and tested again.
If still doesn't work then problem is with the printer formatter board the firmware is corrupted or the board is faulty either one is a hp repair or a second hand machine.
I do hope the first two help you
Thanks J
Jun 07, 2006 | HP LaserJet 9500n Printer
648 people viewed this question
k24674
jasbo
jasbo
