Question about Hayward Pool Products Hayward Northstar 1HP Up Rated Pump
Pump runs for about 3min and shuts off - Hayward Pool Products Hayward Northstar 1HP Up Rated Pump
  • 372 Answers
It sounds like it is overheating. There is a thermal switch that shuts the motor off if it gets too hot. This may be because the motor is pulling too many amps due to a bad winding or the bearings are starting to seize. The best solution is to replace the motor.
Posted on Jan 12, 2013
Replaced the TCM to my transmission, it is still stuck in limp-mode, what do i do next?
depending on the vehicle, try leaven the key in the on position for 30=40 min shut it off wait 3min and do it again shut it off wait 3min turn key on & off seven times then start the vehicle.
Sep 10, 2015 | Cars & Trucks
Carhas problem starting after running for a short time
change air filter, clean all ground wires on engine and spray clean throttle position sensor. after reinstall turn key to on position 3min. then off 3min. this resets it
Apr 01, 2014 | Chevrolet Cavalier Cars & Trucks
Picture of water pump on honda civic ex 1994?
use a stethoscope, mines a electronic, type,Steelman. but
at harbor FRIGHT (pun) the cheap one is only $5
ok,
we drop the belt(s). on a dead cold engine.
we run cold angine for about 3min, max. (water pump is now dead stalled)
no noise now?
make sure all parts connected to the water pump belt are
quite, with a stethoscope, (easy as pie to hear and say good bad.)
use a stick and wiggle the mounts on all accessories.
not running. P/S pump, A/C compressor , Alternator, fix the loose ones.
you can run the engine dead cold with accessories belts off.
sure can.
i never do, (almost) i use my stethoscope.
my comment belt in no way conveys , cam belt ever.
this is an interference engine
so ever do the 60k cam timiing belt service. no , ooops...
get ready for bent valves and VISA card.
Dec 02, 2013 | 1994 Honda Civic
Pump runs for about 3min and shuts off/
That's the motors internal thermal switch doing its job. For some reason your motor is running hot. With the breaker off, remove the end cap on the back of the motor and use a 9/16 open ended wrench to see if the motor shaft turns freely. If it doesn't there may be some debris jammed at the impeller, or the bearings may be failing.
If the shaft moves freely the problem is probably internal to the motor. Usually a bad winding, Northstar pump motors average about 4-5 years, so if it is older than that or getting close the best bet is replacement.
Jan 11, 2013 | Hayward Pool Products Hayward Northstar...
After it as rained all night, I try to start my Saturn SW2 1999 in the morning and the RPM goes up to 3000 and if I put it on drive it will shut off. If I let it run 3min. and shut it off then turn it on...
when u start it up let it run for a second then tap the gas let it idle down then put it in gear. it should run fine then. but its a setup in the staurn comp. its a constant cold start method.
Jul 22, 2009 | Saturn SW2 Cars & Trucks
Hayward Pool Products Hayward Northstar 1HP Up Rated Pump Logo
71 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
