Question about Oregon Scientific RMR329P Atomic Projection Clock LTP0902510311001 LTP090
Projection on my Oregon RMR329P has failed
After switching off the the projection mode before going on holiday, on my return I switched it back on and nothing happens. The clock back- light is working normally. Has the clock failed and needs replacing or is there a remedy?
2 Suggested Answers
SOURCE: I have an OREGON SCIENTIFIC MODEL 323A travel
The following is from a manual I found online. Step 1. and 2. worked to solve the same problem you're having for my sister-in-law. Hope it works for you too--good luck! JLC
SETTING THE CLOCK AND CALENDAR
CLOCK MANUALLY
1. Press and hold [MODE] button for 2 seconds.
2. Using the [UP]/[DOWN] button to scroll through the 4 U.S.
time-zones (Pacific, Mountain, Central or Eastern) or non-U.S.
cities. Press [MODE] to confirm.
3. If non-U.S. city is selected, the world time city will be flashing.
Use [UP]/[DOWN] to select the city (for city names abbreviation,
please refer to the section “Selecting the World Time”). Press
[MODE] to confirm.
4. Repeat the same procedures to set the hours, minutes, year, month,
day, language of day-of-week and hourly-chime on/off by using
[UP]/[DOWN] button.
Posted on Oct 28, 2009
I operated the "Holiday Mode" button on my Model WSE6100WA fridge. After returning the temperature display etc does not illuminate so I can't operate any temperature controls
The eco/vacation mode only exits when the door is opened if it was started automatically by the refrigerator. Since you pressed the eco button, you'd have to press the eco/holiday button until the display shows no icon for the feature.
How long did you have the power off to the refrigerator? Try pulling the plug for a 5 minute power outage. If that doesn't solve the problem, I suspect your appliance may have been damaged by a power fluctuation while you were away. Without additional information, I can't tell if only the display panel is damaged or if something else is wrong. The parts diagrams for the refrigerator are available here: http://spares.bigwarehouse.com.au/index.php?cPath=64685_78487_78846 .
I hope this helps.
Mar 10, 2014 | Refrigerators
Oregon scientific instructions
Which model Oregon Scientific do you have? There are a couple that you need to set the time zone with a switch on the back of the unit. For the BAR388HGA-BK, you press and hold Mode for 2 seconds until it goes into the setting mode. Then you can use the up/down arrows to cycle through the Time Zone options. (1 is Pacific, 4 is Mountain). Press Mode again to confirm the setting and advance to the next item to change. You will leave the Set mode if you do not press a button for several seconds. If you just press and release the Mode button, then you can set the time display option.
A number of Oregon Scientific product manuals are available here:
Technical Support , http://www.oregonscientific.com/us/en/service/support . Scroll down and see the drop-down menu on the right.
I hope this helps.
Jan 25, 2014 | Garden
Accidentally hit wrong button on remote and it switched tv from analog to digital, can't find a way to switch it back
Try going to the menu and changing it back from there! If all else fails then just keep pushing every button on the remote and im sure you will hit the right one!!!!
GOOD LUCK!!!!!!!!!!!!!!!!!!
HAPPY HOLIDAYS!!!!!!!!!!
Dec 23, 2010 | Sylvania SST4322 32" TV
Goes from record mode to standby automatically
Wow my friend do you need Ghost Busters? er no this is mostly a case of the main switch being on lock, or the main IC going down on the panel in the cameras brain area, check the locks first, if it is the chip you will need to call your Sony repair man (He will love you) with summer coming he will be able to go on longer holiday, because that wont be a cheap mend sadly.
Number for help then is 01256 828828, now what you will do for cash for your holiday I simply do not know.
Take care, hope it gets sorted out okay?
Jun 04, 2010 | Sony Handycam CCD-TRV57 Camcorder
Ice dispenser won't dispense
I have a break down of the parts to that unit and I would like you to test a few thing like door switch and power supply at the motor and were the motor gos in. I will return with a like because some reason I believe Fixya must be trying to cut down on photos to reduce bandwith cost. I have to do the same out side of my forum also. Now you wonder where all those ads come from? Hey, you said handy, you may be working around 110 volts and inside a good grounded refrigerator, anyway just need to mention that I do wan't to hear back from you, Sea Breeze
Jan 06, 2010 | KitchenAid KSCS25IN Side by Side...
When turn on, the red light is on (stop blink), but after some seconds the red light is blinking again and the tv remain off
Im not Guarantee This will Work but give it a go
Multi-Region:
  • Turn On the unit with the remote controller
  • Wait until "no disc" appears in the unit's display
  • Press Pause, 3, 1, 4, 1, 5, 9
  • The word "CODE" should appear in the display
  • Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
  • Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
  • Put the player into Standby mode
  • Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
  • Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
  • Press Audio and Return for auto-switching On
  • Press Angle and Return for MacroVision On
  • Press Subtitle and Return for MacroVision Off
hope this helps you out
cheers Little Dish Fitter.
Sep 24, 2009 | Toshiba Televison & Video
I cant get the clock to hold the correct time . Every time i set the clock it goes back in time 2 hours after awhile
Have you tried using the reset hole under (use pin) and setting again? Also after setting you have to press the mode button again to go back into normal mode.If that fails it's probably broken.
Jun 29, 2009 | Oregon Scientific OR-RM313PA ExactSet...
Engine dies when clutch is released or PTO is engaged
flop the seat forward, locate the seat switch in the middle of the seat, push the connector onto the seat switch firmly, start it up and drive away
Mar 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Infocus projector, words projects backwards
change the orientation from rear to front in the menu
Dec 29, 2008 | InFocus In2102 Projector
Machine won't power up after 3 days holiday!
this problem seems to be more electrical device failure as opposed to micro controller confusion. I would look for a failed power supply component, possibly an overheated resistor that has changed value and caused power loss. Look for a browned-out area on a circuit board.
Jul 13, 2007 | Gaggia Titanium Espresso Machine
Oregon Scientific RMR329P Atomic Projection Clock LTP0902510311001 LTP090 Logo
59 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
