Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Black display in lcd in shooting & movie mode
My ixus 75 suddenly started showing only black display in the lcd in shooting & movie mode. But all the fotos taken previously are still viewable. Clock can be seen. Looks like the internal shutter is not opening. No image is seen. Could it be the problem.
  • 1 more comment
  • Anonymous Nov 10, 2007
    I have the same problem. Bought the camera in Dubai in August. Not sur e if the warranty will cover UK
    Sudhi
  • orth0d Nov 10, 2007
    I have the same problem. Bought the camera in Dubai in August. Still under warranty but not sure if it will be covered in UK
  • ewshafarted Dec 06, 2007
    Mine also has a black display but the pictures that I have taken with the camera are still viewable. How would i be able to get it fixed, please?
    Champion:
  • 217 Answers
Your CCD imager is broken, cameras made from 2002 up to 2005 has a weak ccd imager. Company who uses this defective ccd imager recalled all unit and replaced it with a stronger design free of charge. check first their website, find their customer support bulletin, make a copy and show it to their service center.
Posted on Aug 31, 2007
SOURCE:
My canon ixus 75 displays a black screen when in the shoot mode,this happened suddenly while taking a number of pictures,although I can still veiw pictures on the memory card.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When shooting my screen is black and pics. are black
try to take video on Movie mode, if you won't get picture on LCD the CCD is dead. That means you need to replace the whole zoom lens. it costs a lot, not worth to repair.
Apr 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Black LCD monitor on Powershot S410
that is not a malfunction, if the "display" button is pressed, the LCD turns off, (black), but if the mode switch is rotated to movie or panorama, it comes back on but will go black again if switched into the other 2 modes. when in one of the 2 modes that show black, simply press "display" and the LCD will come back on.
FYI "GURU", the CCD malfunction manifests as a purple colored screen with various levels of distortion, not black
Feb 02, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
I have a canon ixus 700 and the lcd screen is blank does not show what i am viewing or piture taken. menu comes up on the screen tho. would any one know the problem thanks andrew
i also have this kind of prob for my ixus. the menu is operating very well, except its shooting - i can only show a black blank screen.
pls help.
Jun 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Image on LCD jumps
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
Blank LCD Screen when in shoot mode
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
197 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
