Question about Siemens Gigaset 200 1Line Cordless Phone
Cannot turn off Gigaset 200
Cannot find off button
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Cordless ph. not holding charge
You should check battery with oher charger. If charges, your problem is tha charger of your phone. Probably you should take it for service and if to expendive, buy a new one
Feb 10, 2015 | Siemens Gigaset 200 1Line Cordless Phone
Gigaset A490 speakphone not working
Does the SPEAKER button light up red when you press it?
Does it work on one handset but not the other? Or does it not work on any handset?
It's a relatively common problem with these phones. It's more than likely broken...
http://gigaset.com/medias/sys_master/A31008-M2200-R301-5-3S19_en_US_CA.pdf
Dec 12, 2012 | Siemens Gigaset A490 Twin Cordless Phone
I wish to find the user's manual for a Gigaset 2420 Desk Station, but neither the Siemens USA or the Gigaset AG have said manuals for download or purchase. Where do I go next?
Here is a link to a free copy of the manual!
http://wedophones.com/Manuals/Siemens/Gigaset%202420%20User%20Guide.pdf
The full manual will load on the page, you may save it to your hard drive or print it out using the corresponding buttons on the upper left of the page! Hope this helps! Have a great evening!
Jul 06, 2011 | Office Equipment & Supplies
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
The screen on the hand set displays searching
PIN restore Gigaset 4010/4015 base
If the PIN code forgotten your Siemens Gigaset 4010 / 4015 base (Classic / Comfort / Micro) then follow these steps to create the reset:
* Take the power cord out
* Press the button and on the bottom of the base and hold
* Insert the adapter into the outlet, hold the base button
* Wait 30 seconds, keep the button pressed
* Wait 10 more seconds and remove the adpter from the outlet
* Put the adapter back in
The unit is now reset and the PIN code is 0000.
Mar 22, 2009 | Siemens Gigaset 4015 Cordless Phone
Gigaset 2420 Siemens
You may have the wrong or defective power supply. Or, that problem is common from getting a power surge and the unit will probably have to be sent in for repair, sorry.
May 05, 2008 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 200 1Line Cordless Phone Logo
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
