Question about Hayward Pool Products Hayward Northstar 1HP Up Rated Pump
Pump runs for about 3min and shuts off/
It clicks when it shuts off and motor is hot?
  • 372 Answers
That's the motors internal thermal switch doing its job. For some reason your motor is running hot. With the breaker off, remove the end cap on the back of the motor and use a 9/16 open ended wrench to see if the motor shaft turns freely. If it doesn't there may be some debris jammed at the impeller, or the bearings may be failing.
If the shaft moves freely the problem is probably internal to the motor. Usually a bad winding, Northstar pump motors average about 4-5 years, so if it is older than that or getting close the best bet is replacement.
Posted on Jan 13, 2013
2 Suggested Answers
  • 372 Answers
SOURCE: pump runs for about 3min and shuts off
It sounds like it is overheating. There is a thermal switch that shuts the motor off if it gets too hot. This may be because the motor is pulling too many amps due to a bad winding or the bearings are starting to seize. The best solution is to replace the motor.
Posted on Jan 12, 2013
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
Motor clicks off after getting hot?
This is a normal function of any pump. When a motor gets too hot it has a thermal cut-off inside so it won't burn up the pump.
Once the motor has cooled down it will come back on.
Look around the motor to make sure it has plenty of ventilation. If it does and the motor keeps shutting down on you I would replace it or take it to a motor repair shop and get it looked at.
There will be something wrong with the motor and that point.
Rod
U S Parts Center
Apr 20, 2014 | Pentair Whisperflo 2 Hp Ur Pool Pump Wf28...
Sunlighter hot tub
Sounds like the pump motor is tripping out on thermal overload. Touch that particular motor just after it shuts off. If it is "very" hot to the touch, it probably needs replacement.
Oct 16, 2013 | Electrical Supplies
Jan 11, 2013 | Hayward Pool Products Hayward Northstar...
Pump shuts off in very hot weather
might have the wrong motor on it, themotor hp and SF sevice facto determin the total HP output of the motor. so say it's a 1hp with a 1.65 sf it's a 1.65 hp motor ..the impeller detrmins the hp needed, it should have numbers and letters on it. welcome to my world fun huh
Jul 10, 2012 | Sta Rite Sta - Rite 2hp Max - E Pro...
I am using an AO Smith motor on a Hayward pump to run my pond. It is about 4 years old now. Most recently, in the hot weather (90+F in the Northeast) the pump just shut off as I was watching the...
pump is protected with a thermo switch made inside the motor to shut it off if it gets to hot check for oil ports at the bearings if it dose not have them maybe try adding a ball valve and turning down the flow some to create slower flow and higher pressure
Aug 31, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Sq1102 hot to touch, how hot should it be? I cannot hold my hand on it.
on to be so hot you can barely put your hand to it. The motor likely has a thermal shut off device on it. If you see "thermally protected" on the motor nameplate, you are safe. If the motor starts to run louder, you will want to replace the bearings and probably the pump seal to avoid a complete failure down the road.
Jun 14, 2009 | A.O. Smith SQ1102 Pool Pump Motor
POLARIS PB-4 3/4 HP BOOSTER PUMP -- body of pump very hot, too hot to hold hand on. 20 amp breaker gets very hot also. Has not tripped the 20 amp breaker yet.
A motor can run that hot and still be within the temperature it can handle. It likely has an internal overload device that will shut it off if it exceeds that temperature. If you see something like "thermally protected" on the motor nameplate, you are ok. If it is getting noisy as it runs it may need servicing.
Jun 08, 2009 | Polaris Pb4 - 60 Booster Pump
Hayward Pool Products Hayward Northstar 1HP Up Rated Pump Logo
57 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
