Question about Kodak EASYSHARE M763 Digital Camera
It is not switching on
It is brand new though it is charged it is not showing any signs of switching on mode
  • Anonymous Mar 28, 2009
    well..
    my camera is one moth old i love itt..
    i can only view my picture i cant take any becaus of some recent problem everytime i turn it on it turns off unless i put it on the favorites dial.
    the i push ►
    and i can view my picturess..
    but i cant take anyy..
    i bought it and im very youngg..
    its alot of mony for em and i dont know wht to doo.!!!
    ive tried everything and it is fully chargedd
    CAN YOU HELP ME!!!!
    Problem Solver:
  • 15 Answers
1. Please male sure that the battery is inserted in the correct orientation
2. For laptops, make sure you have checked the Power Options settings.
a. Hibernate should not be set.
b. Monitor, Hard Disks and System standby should be set to NEVER
3. For desktops, turn off computer's hibernation, standby, and sleep modes.
4. Turn off the camera
5. Connect the USB cable from camera directly to the computer's USB port
if the issue is not resolved, contact kodak at www.kodak.com/go/itg
Posted on Jan 22, 2009
Its brand new but the unit doesnt want to switch on even though i charged it for the recommended 8hours
> it is brand new
Take it back to where you bought it, and get them to either demonstrate that it is working, or for them to honour the warranty, and repair/replace it, at no cost to you.
Dec 24, 2010 | Computers & Internet
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
Camera works in vcr mode but is dead in camera mode. why?
This happened to me once. I found that there is a switch on the back of the camera. It was accidentally moved to the locked position. Once I put the switch back to the standby position, it worked fine.
Jan 06, 2010 | Canon GL2 Mini DV Digital Camcorder
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Camera showing flat batteries
May not work on yours but I have (hopefully had) same issue. I found that it will stay on if you keep pressing shutter to focus or switch straight to video and record - it stays on until you finish recording. I don't know why but after I moved the focus switch from caf to manual, took a couple of pictures and put it back to caf it now stays on.
That was only yesterday though so I cant say its permanently fixed yet.
Let me know if it helps.
Paul.
Paul.
Jun 26, 2009 | Fuji FinePix S7000 Digital Camera
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Kodak EASYSHARE M763 Digital Camera Logo
159 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
