Question about Precor Exercise & Fitness
Precor efx5.21si noise
There is a clicking and rumbling noise when initially using. Typically goes away after 15 minutes of use. Belts look tensioned correctly, running true, and in good shape. Could be a bearing?? I couldn't find any play though.
  • David Sarazen Jan 14, 2013
    The Precor I have is a stair master type, not a treadmill. Thank you, though. Any other ideas are still welcome!
    Top Expert:
  • Precor Master
  • 12,223 Answers
Step 1:
1)First lube the deck belt+rollers bearing see the video and proceed
Step 2:
2) if the problem persist
Time to replace the old board deck belt
Step 3:
3) You must tesst the maim motor bearing+ drive belt
see my personal TIPS for motor helps, and replace if necessary or repair.
God bless you
Posted on Jan 11, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: how do you replace bearing on a precor 9,25 need to replace bearings on precor 9.25
see the videos: God bless you
Posted on Sep 23, 2012
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Precor EFX 546 Version 1 making clunking noise
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
When I start the car there's a loud sqeeking noise that goes away after 1 minute 2003 es 330
if it was mine, I would buy some "fan belt dressing spray" and spray my fan belts or have them adjusted. first spray them once, if sound stops a few days, have the tension adjusted. if spray does not work the first time, this is not the problem.
Apr 16, 2012 | 2004 Lexus ES 330
The engine in my automatic '91 Integra intermittently makes a loud squeaking noise...it sounds to be coming from the left side of the car under the hood. It is not the fan/fan belt, as the noise...
are you sure its not your fan belts? because if fan belts are not turning, it means that the engine is off. check if the tension in your fan belts are still ok. if not, have it re tensioned. if noise is still present, have it changed.
Aug 11, 2011 | Acura Integra Cars & Trucks
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a 2003 Hyundai Santa Fe V6 3.5L with automatic transmission. 48K miles. When I start the car after sitting over night, I hear this whirring/whining noise from the engine compartment. I goes away...
your whining noise might be comming from dry belts in order to pinpoint your problem have a jug of water ready before startup open the bonnet then startup if the noise appears pour water over the belts if noise goes away replace v belts
Jul 13, 2009 | 2003 Hyundai Santa Fe
Engine noise
getting good lubrication flow to the top end of the engine ? maybe some lubrication flow is being blocked to the top of the engine and you hear valve system noise.
Jun 17, 2009 | 2006 Suzuki Forenza
Coustic 800s 4-Channel amp,getting bad rumbling noise.
Sounds like it could be a bad ground. Make sure also you don't have your gain turned up to much on the amp. I know it sounds like a volume control, but it is to balance your input with your output. Also does this noise happen when vehicle is running or off or both.
Feb 05, 2018 | Coustic Car Audio 800S Car Audio Amplifier
Exercise & Fitness Logo
536 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
