Question about Samsung Q430 Laptop
Battery won't hold charge
Message has come up ssaying battery wont hold charge with a red 'X' in the battery icon. I can only use laptop plugged in. I have been using laptop a LOT over the past two weeks and wonder if that has added to problems? do i have to replace battery or is there anythign I can do? I HAVE to use my laptop over the next week.
  • Anna Milser Jan 11, 2013
    in addition I have had the laptop for around 2.5 years. I'm guessing I just jave to replace it?
  • 54 Answers
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Posted on Jan 11, 2013
    Thanks a mil :) I'll try this and if no joy it's off to battery heaven. Just wanted to be sure there was nothing else I can be doing. Much obliged :)
5 Suggested Answers
  • 1768 Answers
SOURCE: why is the red light on when connected to the
1. your battery may need replacement
2. your power supply may need replacement
3. The connection power jack may be damaged and not receiving contact with the power supply.
4. the longevity of a laptop battery can be from 1-3 years max depending on usage.
5. check the power supply adapter with a volt meter to see if it is giving proper voltage.
Posted on Mar 13, 2010
meinverstand
  • 181 Answers
SOURCE: I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
Posted on May 13, 2011
SOURCE: my samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Posted on Apr 05, 2012
  • 564 Answers
SOURCE: sAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Posted on Nov 26, 2012
My laptop won't hold a charge. have a new battery
Is the battery a genuine Dell battery? 3rd party batteries can be high quality or crap, just depends on the maker. Regardless, when you attempt to charge it, does it at least take a charge even though it won\'t hold it? Or does the battery refuse to accept a charge at all? When you plug in your laptop, does the charge light come on? Does the the battery level icon on the lower-right corner of the screen show it\'s plugged in? I know, lots of questions.
Sep 06, 2014 | Dell Inspiron 1420 Laptop
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
What's your problem?ML3109 Notebook wont hold charge
how old is the battery it might be past its use by date if it takes longer to charge the battery needs replacing also check the cmos battery for dust free connection some motherboards cmos batteries are soldered incharge
hope this helps
Jul 17, 2012 | Computers & Internet
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
2004 ford expedition charging system failed?
Sounds like battery not holding charge. Or a light staying on, boot or glovebox? Most likely battery tho.
Nov 16, 2011 | 2004 Ford Expedition
It wont charge consistently. In other words, its plugged in and the batter icon only shows a partial charge.
Sep 06, 2011 | Dell Inspiron 1545 Notebook
My storm battery icon was yellow then went to all red. I have it turned off and charging right now and indicator light is blinking greenish red? Is there a problem or does it just need charged
Battery icon goes yellow when charge is low, red when about to go off, yes, that's OK. Recommend give it more time after all the bars are full-white, to trickle more into the battery. Lithium batteries don't seem to like being flattenend and left flat in my experience.
The light blinks for all sorts of things, might also have pending messages, etc. Can use the Storm OK while it's charging, just hold down red button to turn it on again.
After turning on, sometimes the cellular receiver does not turn on until battery is more charged. Wait 10 mins and then try to make a phone call, you may get a message saying it's off, do you want to turn the receiver on - just say yes.
That should keep you going. Nice phone.
Sep 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
Samsung Q430 Laptop Logo
147 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
